1. J1NxFlow's Avatar
    Hello I need help I have a Samsung Galaxy Note 3 IDK why my battery dies so fast like it's on 100% and on like 20-30 minutes is already on 8% I also need help my tocuh with tve finger does not work i can only use ir with the pen that comes with the phone please someone help any solutions?
    08-12-2018 06:40 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! How old is the battery? Chances are that it's failing. Try a new or different battery.
    If the phone never responds to touch, then the touchscreen digitizer has probably failed. You can still use the S Pen because that uses a different technology to register a touch.
    08-12-2018 09:30 PM
  3. Fulani Filot's Avatar
    1. Battery issue: What version of Android is your SGN3 running? Mine was upgrade from 4.4 to 5.0. Unfortunately when that was done successfully, the power management aspect of 4.4 wasn't overwritten (what it seems like) by that of 5.0 and as such, my battery charges very fast and drains very fast. I've been advised to get the stock ROM for my region (which finding is easier said than done) and flash my phone (also an SGN3, SM-N900).
    2. Screen touch issue: try dialing the phone number *#0*# to call up a hardware test service menu hidden in the phone (on typing the last character -the hash- the menu will appear). Watch the video I've shared via:
    https://www.dropbox.com/s/72kxccb0w9...rator.mp4?dl=0
    (at the Dropbox login prompt, select "No thanks, continue to view" to watch video...if you don't have/need a Dropbox account)
    I did it on my phone. I don't know if/how much it will work to resolve your touch issue but I guess its worth a try.
    10-10-2018 07:07 AM
  1. Ultimate Camera Test - Note 9 vs iPhone X
    By NIZMOZ44 in forum Samsung Galaxy Note 9
    Last Post: 08-13-2018, 10:27 AM
  2. Replies: 1
    Last Post: 08-12-2018, 09:36 PM
  3. Why is my phone so slow
    Last Post: 08-12-2018, 05:42 PM
  4. Replies: 1
    Last Post: 08-12-2018, 04:46 PM
  5. I am using snapdragon 820 my one core cpu2 is showinge off line
    By Android Central Question in forum BlackBerry DTEK60
    Last Post: 08-12-2018, 04:11 PM
