07-21-2015 03:36 PM
983 ... 2627282930 ...
tools
  1. nugj's Avatar
    That Supcase is a very nice looking case...well made..port covers with something like hinges. Looks like they won't break easily. Only caution...same one we VzW carrier variant customers are going to have to be watchful for.....that left side mic hole just looks like the standard round hole...gotta' be a problem for the VzW variant.
    10-23-2014 09:36 PM
  2. Matthew Brill's Avatar
    Just got the Ballistic Tough Jacket. Replaced my Spiegen Tough Armor. Much more grip on the back, still pretty slick plastic, but there's a big difference between the two. I actually feel comfortable holding my phone now. Also, the power and volume buttons press very easily, whereas the tough armor buttons required quite a bit of pressure. Some pics:
    Note 4 What case you going for?-1023142142.jpgNote 4 What case you going for?-1023142142a.jpgNote 4 What case you going for?-1023142142b.jpgNote 4 What case you going for?-1023142143b.jpg
    stanleybb50 likes this.
    10-23-2014 09:57 PM
  3. bertsirkin's Avatar
    Nice. How is the feel of the back?
    sent from my Samsung GALAXY Note® 4 using Tapatalk
    The back feels fine BUT, there is a BIG FLAW in this case!
    As you can see in this picture, the case covers the microphone! YOu cannot make phone calls with the case on, because the other party won't hear you.
    10-23-2014 10:23 PM
  4. keyzlife's Avatar
    Is yours the Verizon variant?
    10-23-2014 10:25 PM
  5. aparker2005's Avatar
    My ringke fusion case works awesome and looks great. The screen protector it came with does good for me. I have 1 little bubble but it's fine. May get another case but I like that it shows the white with a black trim.
    Sent from my SM-N910V using Tapatalk
    10-23-2014 11:33 PM
  6. jrm89's Avatar
    Just got my crystal clear case. Snug fit, slim and show my black sexy note 4
    I'll be returning the s-view. It's nice but doesn't provide protection from drop.
    That's the case I'm using at the moment, at least until I receive my Spigen Tough Armor case! I'll make my decision on which to actively use after I've spent time with both but I am liking the Ringke Fusion more-so than I previously believed I would!
    10-24-2014 01:16 AM
  7. bertsirkin's Avatar
    Yes, the phone is from Verizon.
    10-24-2014 07:53 AM
  8. bertsirkin's Avatar
    Here is the bottom on the neo hybrid and my vzn n4. The mic hole on the left is off. Attachment 143009
    EXACT same issue with my Caseology case (orums.androidcentral.com/samsung-galaxy-note-4-accessories/439875-note-4-what-case-you-going-28.html#post3990805)
    10-24-2014 07:55 AM
  9. tdgwf's Avatar
    You have Verizon. They are the only idiots that decided to have their mic in a different spot...
    10-24-2014 08:21 AM
  10. nugj's Avatar
    Well just not to make this seem like a VzW decision made in a vacuum or even a VzW decision about the mic hole.....
    All the carriers support different base line technologies. They all have to be backwards compatible with technologies they have supported that are still active in some territories and they own different frequency blocks in different territories. It is likely the technology piece that forces different radio trays into the N4 by carrier. That also probably means the trace lines between the radio tray and some antennas are different for any antenna not actually mounted somehow to the radio tray. While this is only my opinion and a guess, I would guess it is that difference that forced the VzW N4 to have a different location for the left side mic and even a tunnel or funnel that funnels your voice up to a mic that is actually to some extent set back from the edge of the housing.
    10-24-2014 09:46 AM
  11. thegame161's Avatar
    Might get this
    10-24-2014 10:10 AM
  12. bigredinmass's Avatar
    Following up on my 'anti-Spigen' post from yesterday (sorry if I offended anyone - was just going through my reasoning on case selection), a buddy of mine ordered the Spigen Strong Flex Capsule case as a temporary case for his Verizon phone. He called me after he picked up his phone from BB (still waiting on my email to get phone from Braintree, MA BB) and he sounded very muffled. Same problem as noted by others - the mic hole for the VZ version phone is covered up. Once he took that case off, he sounded fine.
    10-24-2014 10:52 AM
  13. delco714's Avatar
    I have spigen slim. In general OK. Very slippery, the kickstand is garbage. I think it'd take a fall well. The lip over the screen isn't huge but would be OK for falls on flat surfaces. Uneven, not so much, likely. .
    10-24-2014 11:22 AM
  14. delta7's Avatar
    anyone who ordered the spigen wallet case got it yet?
    http://www.amazon.com/Galaxy-Spigen%...cUvbUpU3992682
    10-24-2014 03:25 PM
  15. TechNut79's Avatar
    I ended up with one from Tech21 after the Spigen debacle.
    DL1991 likes this.
    10-24-2014 03:35 PM
  16. butterfly210's Avatar
    Hmmmn... My mic holes r round but I got Tmobile
    10-24-2014 03:43 PM
  17. butterfly210's Avatar
    I have Spigen neo hybrid holes r ok
    10-24-2014 03:45 PM
  18. butterfly210's Avatar
    Got this one today and love it!
    I have the similar 1 except mine is spigen in same colors posted a few pages back... Lol they r awesome cases...
    10-24-2014 03:46 PM
  19. TechNut79's Avatar
    You're on T-Mobile, that's why.
    10-24-2014 03:51 PM
  20. amzi160586's Avatar
    I've just decided to go for the ringke slim in gun metal.. lets see how this holds uo
    10-24-2014 03:52 PM
  21. mchi5's Avatar
    Seidio has released their Surface for the Note 4 w/ or w/o belt holster.
    Thanks for the heads up. Gonna check it out
    Sent from my new Note 4 via Tapatalk
    10-24-2014 08:15 PM
  22. nugj's Avatar
    Hey is that one of those Tech21 mesh deals? How do you like it? I just did not know what to think of it on the rack. I do give them credit for the way they designed their retail packaging. You can get into the box and get a much better look at the mesh stuff.
    10-24-2014 08:28 PM
  23. TheDonJ77's Avatar
    I want this one but it doesn't ship until Monday. They only offer free ground shipping from California and that's gonna take too long coming to DC. I'm hoping Amazon will have it on Monday and offer prime shipping.
    10-24-2014 09:01 PM
  24. Shamrock_627's Avatar
    UAG shipped early for me! I received it today (wasn't suppose to ship until 10/27). It's more compact than I thought it would be.
    10-24-2014 11:30 PM
  25. Michael Duggan's Avatar
    My phone is vzw note 4 and I bought a spigen, holes did not line up. After some drilling... now they do lol. Anyone have links to VZW note 4 case that do not require drilling? The vzw accessories are limited.
    10-24-2014 11:42 PM
  1. Samsung Galaxy Note speaker not working.
    By patrickmbennett in forum Ask a Question
    Last Post: 09-23-2014, 03:45 AM
  2. Replies: 1
    Last Post: 09-22-2014, 06:28 AM
