07-21-2015 03:36 PM
983 ... 34567 ...
tools
  1. Tarek53180's Avatar
    they do go check best buy
    I hoping tech 21 comes out with a case.
    10-06-2014 10:12 AM
  2. prakash99's Avatar
    I want one with a beltclip - like Otterbox. What other options are there?
    10-06-2014 11:03 AM
  3. thegame161's Avatar
    My white s view cover has shipped
    10-07-2014 02:55 AM
  4. Shamrock_627's Avatar
    I think I am going to hold out for UAG
    10-07-2014 03:28 AM
  5. reesh11's Avatar
    Where did you order it from?
    10-07-2014 06:33 AM
  6. Sabban's Avatar
    What are some good belt pouches for the note4? Not belt clips that the phone will clip into but actual pouch that the phone will slide into completely.
    10-07-2014 06:49 AM
  7. gottria's Avatar
    Check out Seidio, they have some nice cases that use a really sturdy belt clip. I also found out that other cases will fit just fine in their belt clips but it's trial and error. Also Best Buy sells their Platinum series that is a case and belt clip that is the same ones Seidio sells as their surface series.
    prakash99 likes this.
    10-07-2014 08:50 AM
  8. fulleraj's Avatar
    Has anyone experienced any issues with certain styles of cases interfering with tempered glass screen protectors on previous devices?
    Sent from my GT-I9505G using Tapatalk
    10-07-2014 09:06 AM
  9. Eclipse2K's Avatar
    Generally you'll be fine unless the case has a lip that almost hits the circular menu button on the bottom. Those just barely touch the protector and cause it to have a slightly rough edge. The only case I've seen with this issue is the Galaxy S5 OEM case.
    Samsung Galaxy S5 (Verizon)
    fulleraj likes this.
    10-07-2014 03:12 PM
  10. thegame161's Avatar
    Mobile fun.Co.Uk
    reesh11 likes this.
    10-07-2014 04:46 PM
  11. brothamoveson's Avatar
    I like my phones naked so I will not be buying a case.
    10-07-2014 05:12 PM
  12. Michael Maloney1's Avatar
    naked my thoughts exactly. everyone says OMG no case, life protected shatter watertproof etc. i say no. i buy the phone i like its looks and thinness. why salp a case and protector.
    i think screen protectors are the biggest bunch on bull ever. a 50 cent peice of plastic will resist more than gorilla glass. cmon. i have never used one and all my phone are impeccable for i resell them yearly to upgrade.
    to each his own not knocking peeps who use a case but half the marketing scares you to buy something to fugly up your phone.
    10-07-2014 08:02 PM
  13. TechNut79's Avatar
    I don't buy fugly. I have an UAG on my phone now. I plan on a Spigen or Verus. Defintely look good.
    Note 2 via Android Central App
    10-07-2014 08:20 PM
  14. maj71303's Avatar
    my case just shipped which was Galaxy Note 4 Case, Spigen® [STRONG-FLEX] Galaxy Note 4 Case
    10-07-2014 08:44 PM
  15. Eclipse2K's Avatar
    Tempered Glass protectors do indeed protect and feel as good as naked glass. I am anal so any scratches drive me nuts. Even a micro you only see in direct sunlight.
    reesh11, PaulaO and mchi5 like this.
    10-07-2014 08:47 PM
  16. TechNut79's Avatar
    So Eclipse, which protector do you use? I used to use screen protectors religiously until one rolled off. Then I stopped and my current device's screen is covered in small scratches. Maybe tempered is better and easier to apply?
    10-07-2014 08:58 PM
  17. MHoward29's Avatar
    I have an S View on my S4, I'm kinda worried that the Note 4 version doesn't have felt on the inside. Am I just worrying for no reason?
    That being said, I already ordered a slim armor, gf has one on her S5 and I like it a lot.
    10-07-2014 09:02 PM
  18. Eclipse2K's Avatar
    Zagg Glass
    It's $39.99 at Best Buy with a lifetime warranty. In the event you need a new one due to a bad installation, damaged protector, replacement device or any other reason, you can get a new one for $5.99. They will send you the new protector and you send yours back with a single postage stamp. Like most of the Tempered Glass, its 9H rated so the odds of any damage unless dropped is slim.
    Very easy to install. Do it in a room with as little dust as possible such as a steamy bathroom after a shower. If a spec of dust gets in there it won't bubble up but you may see the dust on bright white screens as you'd expect.
    10-07-2014 09:05 PM
  19. reesh11's Avatar
    Zagg Glass
    Are these available now? I was trying to go protector-less since I'll be using an S-view and the Note 4 screen is major thick. But like a few posts above I am borderline OCD (don't EVER fold my towels into squares!) when it comes to things like this. So I am looming at reviews of these all. Never had tempered glass and don't want to pay two legs since I already bought $80 worth of accessories...is it the 17th yet?
    10-07-2014 09:27 PM
  20. Eclipse2K's Avatar
    Its listed on Best Buys website as coming soon. Keep an eye out for it.
    I'm also not sure it would allow the Sview to close properly since it adds a bit of thickness.
    10-07-2014 09:36 PM
  21. reesh11's Avatar
    Oh yea didn't even think about that. Well I suppose I'll go sans protector for a little while. You gotta take risks every now and then right?
    10-07-2014 09:43 PM
  22. GoProDavidLe's Avatar
    Does anyone know any websites that have aluminum/metal/alloy bumpers for the Note 4?
    10-08-2014 08:46 AM
  23. m3lover1's Avatar
    I'm Gonna get the verus slim one, with metal sides. Wanted the s view but I hate the damn horizontal creases on the front and back. I will only use the case on vacation or going out to the race track etc anyways, I normally use my phone naked.
    Sent from my Nexus 5 using Tapatalk
    10-08-2014 01:54 PM
  24. Beltelmel's Avatar
    Looks like there might be a new S View without creases coming. Can't post a link but several sites including mobilefun and expansys describe it as "smooth". Part number (EF-CN910FKEG for black) is different than the one now currently available. Listed a "classic" black as opposed to charcoal which I would imagine will make it blacker than the N4 itself. Due in stock tomorrow.
    Katrina White1 likes this.
    10-09-2014 02:38 PM
  25. Douche Bigelow's Avatar
    Got the Spigen Neo Hybrid.
    10-09-2014 09:30 PM
983 ... 34567 ...
  1. Samsung Galaxy Note speaker not working.
    By patrickmbennett in forum Ask a Question
    Last Post: 09-23-2014, 03:45 AM
  2. Replies: 1
    Last Post: 09-22-2014, 06:28 AM
