Samsung Galaxy Note 4 Wireless charging back cover
Re: Wireless charging back cover
Nope there is one on amazon that is just the insert. You can use it with the original back of the Note 4. You're welcome.
Do you have the link?
Yes the Samsung wireless charging back does make the note 4 thicker. It makes the rear facing camera flush with the back cover. I think its worth the additional thickness and not having to worry about damaging the camera lenses.
Sent from my SM-N910T using Tapatalk
Oh good point. I hate camera protrusion. I just wish cases were made for it.
And there it is! :cool:
I'm with you on this one. The fact that there are no cases to fit it makes it worthless to me. I'm very meticulous about keeping my phone in pristine condition. The fact that I have to pick either protection or wireless charging is very frustrating.
-Shawn
Noting the world one S-Pen at a time
-Shawn
I would like to believe that I'm the same way with my SGN.IV, though I do not consider the Samsung Galaxy Note 4 Wireless Charging Battery Cover to be worthless since I have to make it work for me and my uses. And while having the wireless battery cover, I also decided to go with the Krusell Tumba Mobile Case 5XL.
Of course Your Methods May Vary accordingly so.
