Question for those that have bought this case - Does the belt clip on the holster rotate or is it fixed in one position?
Thanks
It rotates with quite a bit of effort. One might think it wasn't meant to rotate if they weren't told otherwise. I find it to be unwieldy on my belt, though, so I don't use it.
Anyway, I got this case too, and it both looks and feels quite good. I popped out the screen protector that came with it, so I can't speak to it's efficacy. I can say that the case installs/uninstalls very easily if you follow the instructions; If you somehow have managed to drain your battery, it won't be tough to get the case off. I also suspect that if you wanted to replace the built in screen protector with a glass one, the case would still work fine.
Most importantly to me, it feels like it would protect the phone from a reasonable drop, which I really couldn't honestly say about the Spigen Tough Armor that I tried. It doesn't go in and out of the pocket as easy as the Spigen, however - Not great news for those of us who don't like the belt clip. I do love the port covers, which was a major selling point for me. They aren't seamless or perfectly aligned, but I wouldn't call them ugly either. More to the point, they are very practical and work well.
I have yet to make a call with this case on, so the jury is out on whether or not the bit of engineering they did to get it compatible with my Verizon phone was sufficient for call quality. I've used voice recognition quite a few times, however, and that works just as well as it ever has - probably a good sign.
Overall, I bought this phone because it was a comparatively inexpensive, impact-resistant case with port covers. I suspect this case might disappoint some people, but it is exactly what I wanted to hold me over until something better came along.
I have my eye out for Trident.
