Samsung Galaxy Note 4 Spigen UC Cases
Eclipse2K
5,722
107
Re: Spigen UC Cases
They didn't know. Chill. They are willing to give a refund. There's also a problem with the mic holes not matching on certain models. I'm sending mine back for a refund.
I'm more or less referring to sharper edges. Spigen makes great products but there are things a case manufacturer should ensure and that's to be sure wearing a case won't damage the device. I'm sure they didn't know this would happen but its still disappointing either way.
Samsung Galaxy S5 (Verizon)
Yogi217
641
Re: Spigen UC Cases
Wow. I bought this case and was looking forward to using it (once my freaking phone shows up), but I'm going to send it back. Unacceptable for a case.
91DBrown
Active member
Oct 14, 2014
36
Re: Spigen UC Cases
Here you can see the micro scratches. I don't know if we can blame spigen yet as it may be a problem of debris getting into the creases rather than the case itself. I'll start a new thread to see if other cases are doing the same!
Preach2k
1,967
115
63
Re: Spigen UC Cases
I wonder if Neo Hybrid does the same thing.
I asked a friend of mines he said No. His is not scratched at all because rubber covers the whole phone. The only thing touching the Aluminum is rubber nothing hard that can scratch the Aluminum. He also drilled an hole in his Neo Hybrid to fix the mic situation on his GNote4 on Verizon. I will do the same when I get my phone Friday. I already have the Neo Hybrid case.
Preach2k
1,967
115
63
Re: Spigen UC Cases
I think it is how you put it in the case. Like I said a friend of mine has the Neo Hybrid on his. He said that his has no scratches. You have to remember Aluminum is a soft metal. You can not force it in a case like you did your old Samsung Notes 3, 2,and 1's. They had plastic all around them. Separate the 2 pieces first . Put the GNote4 in the rubber case first then put on the Bumper on.
MrDioji
Active member
Sep 18, 2012
28
I was considering drilling a hole for mine, but I also can't get the heartbeat monitor to register with the case on, and my aux cable in my car doesn't fit in the headphone jack hole. I think I'm just gonna have to return it. Which is a shame because it's a beautiful case with just the right combo of slimness and protection for me.
Oh, and I've had no scratching in the 2 days of using the neo hybrid.
sforsyth01
373
Re: Spigen UC Cases
Are they buying the customers a new phone too since their product damaged the phone? I feel they should. I absolutely baby my phones to avoid scratches like this and would be beyond angry if a product I bought to protect it caused this kind of damage.
-Shawn
Noting the world one S-Pen at a time.
felloffthetruck
Trusted Member
Mar 31, 2013
8,609
21
38
Re: Spigen UC Cases
Would you say both Neo Hybrid and UC have the same design on the inside?
Yes, they do. The lip that goes over the face edge of the phone is very thin and sharp. Kind of like a rubber razor blade. I can see where these sharp edges could scratch that shiny aluminum bezel of the Note 4.
After feeling those edges and the mic holes not lining up, I never put my phone into either case.
They are heading back to Amazon.
carraser891
424
3
Re: Spigen UC Cases
I'M disappointed in the Spigen cases.They don't even have the right cutouts For the mics on the bottom . Went with a Otter box Commuter and couldn t be happier
Eclipse2K
5,722
107
Re: Spigen UC Cases
After feeling those edges and the mic holes not lining up, I never even put my phone into either case.
Any pictures of the edges that cause this?
Android4life47
226
Re: Spigen UC Cases
That's why I always use a outterbox it may cost more than some of the other cases out there and add thickness but at less I don't have to worry about things like this
Preach2k
1,967
115
63
Re: Spigen UC Cases
This is what a guy I know did:
respibob
Active member
Dec 30, 2010
30
Re: Spigen UC Cases
I have the Slim Armor dual layer. I'm not taking mine out to check lol. It went in easy though, so I hope that means no scratches.
Posted via my awesome Note 4
Preach2k
1,967
115
63
Re: Spigen UC Cases
2 of my friends with Neo Hybrids say The Do Not have scratches on theirs at all. MrDioji had his case on for 3 days and he has no scratches. Tomorrow at church I will see one of my friends with his Gnote4 with a Neo Hybrid Case. I will take a picture of his phone to show that he has no scratches.
HOLLYWOODANT215
777
31
Re: Spigen UC Cases
Same way i felt im not taking the case off to find out lmaooo..but i wanted to show my dad how slim phone is so i took it off i was so nervous its was scratches but it was fine
fredwardnelson
244
Re: Spigen UC Cases
-Shawn
Nah, you know they ain't doing that. I think they should too though. My Note is back-ordered so I'm waiting for it. I might just go with the Note Edge instead though since it's made of plastic instead of metal.
Lambertoid
206
11
18
Re: Spigen UC Cases
Just posted in another thread and I also have the spigen capsule and I took it off yesterday for the first time and noticed the scuffs so now debating to get a uag case or what to get to protect it.
91DBrown
Active member
Oct 14, 2014
36
Re: Spigen UC Cases
I doubt there is much we can do to stop this from happening. It may just be best to stop in at a jewelers every now and then and see if they can polish it up. There's also the sandpaper method from the iPhone 5, however I would be worried about the painted part of the aluminum.
kludger
16
Re: Spigen UC Cases
I've been using a Spigen New Hybrid and Rimke Slim and I just checked and no scratches so far, I'm going to be extra careful when removing it from the cases.
akbarramadhani12
