1. felloffthetruck's Avatar
    Do the new UAG Note 4 cases have the elongated microphone hole on the bottom so it will work with the Verizon Note 4?
    Thanks.
    10-25-2014 07:38 AM
  2. ohbreeeezy's Avatar
    10-25-2014 11:23 AM
  3. felloffthetruck's Avatar
    Thanks, Breezy
    Just went to order the Maverick and it is Sold Out again.
    I can't get a case to save my life.
    TheDonJ77 likes this.
    10-25-2014 11:59 AM
  4. jetman5843's Avatar
    The case will work since the speaker hole is slotted on the bottom to accommodate all models. Great case!
    10-25-2014 12:48 PM
  5. Notrega's Avatar
    Is the hole around the speaker level with the rest of the back? My Otterbox Commuter has a raised area around that cut out so it doesn't lay flat.
    10-26-2014 02:12 PM
  6. Alexander Burnside's Avatar
    I'm considering the commuter. May I ask why it matters if the phone lays flat or not?
    10-28-2014 12:22 PM
  7. Notrega's Avatar
    Using the S-Pen it helps if it lays flat...
    10-28-2014 06:25 PM
  8. Alexander Burnside's Avatar
    I don't have a case yet, so it neither lays flat nor does it stay still while drawing. It never bothered me though, so It'll be interesting to see if it makes a positive difference.
    For the record, this is the case I decided on until Trident releases a case for the Note 4 (Mid-November). It has feet on the back, which leads me to believe it'll lay flat.
    10-29-2014 09:31 AM
  9. jspring86's Avatar
    Just got my Urban Armor case and it works and looks great with the Verizon Note 4. It was a tight fit so I am a little concerned I may have scratched the aluminum, which is bad since I like to change cases often. Love everything else about it though.
    Samsung Galaxy Note 4 Does the Urban Armor Gear Case work with the Verizon Note 4? UAG-imageuploadedbytapatalk1414796013.188274.jpg
    Samsung Galaxy Note 4 Does the Urban Armor Gear Case work with the Verizon Note 4? UAG-imageuploadedbytapatalk1414796022.735865.jpg
    10-31-2014 05:53 PM
  10. felloffthetruck's Avatar
    Looks good. How hard is it to get out of the case?
    10-31-2014 07:03 PM
  11. nugj's Avatar
    I asked that question here and the answer back was "h*ll on wheels".
    10-31-2014 08:14 PM
  12. jspring86's Avatar
    It's not a picnic to get out, I can see a few micro scratches, but nothing really serious. Someone else mentioned they were able to get those out with some aluminum polish and a cloth.
    10-31-2014 09:47 PM
  1. Samsung Galaxy Note 4 S-Pen too sensitive. how to adjust?
    By nateobomb in forum Samsung Galaxy Note 4
    Last Post: 01-13-2019, 12:13 PM
  2. Replies: 30
    Last Post: 11-19-2014, 04:34 PM
  3. Samsung Galaxy Note 4 Anyone using @Keeper?
    By Beltelmel in forum Samsung Galaxy Note 4
    Last Post: 11-01-2014, 11:55 AM
  4. Samsung Galaxy Note 4 So glad I got White!
    By GtoJon in forum Samsung Galaxy Note 4
    Last Post: 10-29-2014, 09:51 AM
  5. Replies: 1
    Last Post: 10-28-2014, 08:13 PM
