1. seoulbrova's Avatar
    Saw this on ebay last night
    Hippocampal Buckle Thin Metal Bumper Case Cover for Samsung Galaxy Note 4 N9100 | eBay
    Look at the bumper, there are cut outs in the aluminum where the antennae is. Would this case suffer from signal loss? I remember the aluminum bumpers for the Note 2 and Note 3 would have weaker signals and/or loss of GPS ability.
    Anyone have experience with these?
    Thanks
    10-25-2014 12:48 PM
  2. MedusaOblongata's Avatar
    I'd like to know also, as I was considering a minimal case like this one.
    11-01-2014 03:51 AM
  3. curney's Avatar
    I ordered one of these yesterday or friday. found a us seller. should be here in a few days. 7 bucks shipped.
    Thanks
    11-01-2014 04:15 PM
  4. livetoride4666's Avatar
    Thanks
    Yes and don't buy it! I bought this bumper, but from a different seller on eBay. I received the bumper yesterday and threw it away. VERY CHEAP and does not fit very well. It will scratch your phone if you leave it on.
    sforsyth01 and curney like this.
    11-01-2014 04:24 PM
  5. curney's Avatar
    well, there goes $7.
    11-01-2014 04:43 PM
  6. MedusaOblongata's Avatar
    Does anyone make something quality in a similar form factor?
    11-07-2014 09:52 PM
  7. eclectic11's Avatar
    I have both a note 3 and 4. I have one of these for my note 3 and had concerns about signal loss before I got it. I purchased the brand iClover from Amazon. It looks really nice and turned my note 3 into almost a large Galaxy alpha in appearance. Immediately I noticed a MINIMAL drop in signal and I was pretty sad about it because it looked so good! I was also concerned about scratches but that never happened. The inside is lined with tape or something like it. However not all brands are the same. It fits snug with two screws on one lower corner. What is great is that just before I got my note 4, I was debating whether I should just stick with the 3 so I did a factory reset to see if I could improve its performance. After I did the reset all the signal drop issues completely dissappeared. It works great now regardless with or without the bumper. I will likely stick with my note 4 the way it is though based on the metal design. But I may just order when it hits iClover and Amazon.
    curney likes this.
    11-07-2014 11:24 PM
  1. Samsung Galaxy Note 4 S-Pen too sensitive. how to adjust?
    By nateobomb in forum Samsung Galaxy Note 4
    Last Post: 01-13-2019, 01:13 PM
  2. Samsung Galaxy Note 4 otterbox commuter
    By reesh11 in forum Samsung Galaxy Note 4 Accessories
    Last Post: 03-08-2015, 07:00 PM
  3. Samsung Galaxy Note 4 Anyone using @Keeper?
    By Beltelmel in forum Samsung Galaxy Note 4
    Last Post: 11-01-2014, 12:55 PM
  4. Samsung Galaxy Note 4 So glad I got White!
    By GtoJon in forum Samsung Galaxy Note 4
    Last Post: 10-29-2014, 10:51 AM
  5. Samsung Galaxy Note 4 Samsumg Pro 64gb SD Card
    By suitebliss in forum Samsung Galaxy Note 4
    Last Post: 10-28-2014, 07:56 PM
