1. yesshh's Avatar
    I have been trying to do some research and haven't come up with any conclusions on what I want to do for an additional charger or battery.
    What solutions have you fellow Note 4 lovers came to in regards to purchasing an extra battery and/or charger.
    I am having some issues with battery initially, but am going to make a separate post in the other forum after a couple days of use with my battery results.
    Thanks!
    11-05-2014 11:40 AM
  2. iGalione's Avatar
    I always purchase the spare battery kit from Samsung which allows you to have a spare battery to pop in, when you need it, and the charged to charge it up... I recently also bought their 9000 mAh which was on sale for 34.99 and that works pretty good, not the fastest charge on the planet, but it works in a pinch as well.
    Hope this helps...
    Thanks!
    11-05-2014 03:41 PM
  3. johnnygod's Avatar
    I bought the spare battery kit when I bought my Note 4.That had been what I've used most so far. It's great because it comes with its own charging case, so I can charge the spare in the break room at work while I'm using my phone at my desk. I also just bought a RavPower 14000 mAh external battery that I use while hiking. It's as heavy as a brick but I can get almost 4 charges with it and I don't have to be tethered to a wall.
    Katrina White1 likes this.
    11-06-2014 10:03 AM
  1. Severe Battery Drain
    By Ikeman90 in forum Google Nexus 5
    Last Post: 11-06-2014, 09:35 AM
  2. Nexus 6 Battery life
    By Ricky Prasad in forum Google Nexus 6
    Last Post: 11-05-2014, 08:57 PM
  3. Replies: 4
    Last Post: 11-05-2014, 01:30 PM
  4. Battery getting drain within a minute when reaches to 25-30%.
    By Shafiullah Choudhary in forum Samsung Galaxy Grand
    Last Post: 11-05-2014, 12:49 PM
  5. Replies: 1
    Last Post: 11-05-2014, 12:15 PM
