02-21-2015 09:59 AM
131 12345 ...
tools
  1. comfortably nub's Avatar
    I'm waiting for the incipio feather case for the note 4. I have used them on my last two phones and love them
    Note 3 version;
    feather Ultra Thin Snap-On Case for Samsung Galaxy Note 3 | Incipio
    ecs180 and pantlesspenguin like this.
    11-12-2014 09:31 PM
  2. eao1991's Avatar
    wont work with the verizon version though huh.
    Verizon has a Tech21 case available on their site that's compatible with the mic. Looks better than the all black Tech21 case.
    Sent from my Note 4
    Dru419 likes this.
    11-12-2014 10:25 PM
  3. V J's Avatar
    Just got the Spigen Neo Hybrid today. It's not ultra-thin but it's not bulky by any means and the quality is just really impressive.
    Best thin case for Galaxy Note 4?-20141113_140043.jpgBest thin case for Galaxy Note 4?-20141113_140222.jpg
    Preach2k, bdgriff, Dru419 and 2 others like this.
    11-12-2014 10:52 PM
  4. jerseygirl's Avatar
    Ringke Fusion Clear for the Note 4 is my pick. Shows off the Note 4 quite nicely, is thin, and has port covers for the headphone and charger slots. Picked it up from Amazon for 9.99 although it seems like the price has dropped on Ringke's website directly.
    That's what I went with...it's barely noticeable. At one point I thought it was defective, lol...I didn't know there was a thin protective cover which started to bubble up. I was ready to send it back until my daughter told me to just peel it off!
    11-12-2014 11:13 PM
  5. ajneuman's Avatar
    I have this case and I really like it. I also have the spigen neo hybrid and it's way to bulky for me.
    Attached Thumbnails Best thin case for Galaxy Note 4?-screenshot_2014-11-12-21-41-48.jpg
    11-12-2014 11:45 PM
  6. Marley's Avatar
    Does anybody know if Spigen is going to make a Note 4 hard flip case. I had one on my G4 and it was the best case I've ever used.
    11-13-2014 12:06 AM
  7. tester2013's Avatar
ID:	147843Click image for larger version.
    Does this case cause scratches anywhere? especially on the metal?
    Thanks
    11-13-2014 01:14 AM
  8. V J's Avatar
    Thanks
    Really highly doubtful, the inside of the case is a rubbery / jelly texture.
    11-13-2014 02:21 AM
  9. Preach2k's Avatar
    Thanks
    No I have this case in Gun Metal. Separate the Bumper and The TPU 1st. Put phone in TPU, then put the bumper on. I have no scratches at all on mine. I seen people scratch theirs because they do not take their time putting it in the case. Just force it in the case with out separating it. I have an back up battery so I swap it out a lot. No scratches at all..
    11-13-2014 02:21 AM
  10. sforsyth01's Avatar
    Is the case slick in your hand or rubberized?
    I have a similar one to this and the sides are tpu rubbery but the back is plastic. Very good feel in my opinion.
    -Shawn
    Noting the World One S-Pen at a Time
    11-13-2014 07:23 PM
  11. mgm83's Avatar
    I have 2 of these and love them..plus they are cheap. Rearth Ringke
    Attached Thumbnails Best thin case for Galaxy Note 4?-screenshot_2014-11-13-20-29-18.jpg
    5uck3rpunch likes this.
    11-13-2014 07:30 PM
  12. alhadee12's Avatar
    -Shawn
    I'm looking for a nice slim case.
    11-13-2014 07:53 PM
  13. LordAndroid's Avatar
    Here's mine by Spigen
    Sent from my SM-T700
    Attached Thumbnails Best thin case for Galaxy Note 4?-uploadfromtaptalk1415935281385.jpg   Best thin case for Galaxy Note 4?-uploadfromtaptalk1415935297536.jpg   Best thin case for Galaxy Note 4?-uploadfromtaptalk1415935310482.jpg   Best thin case for Galaxy Note 4?-uploadfromtaptalk1415935334406.jpg
    11-13-2014 09:22 PM
  14. tester2013's Avatar
    Hey,
    Hows this case? Does it have protection if it falls?
    11-13-2014 10:42 PM
  15. GrassyKnoll312's Avatar
    Curious, have you had any issue getting it on and off? I like the one I got but it is so tight it's a struggle to get it back off again once it's on.
    11-13-2014 11:00 PM
  16. LordAndroid's Avatar
    Hey,
    The top and bottom of the device are open and exposed to possible damage if impact came to those areas.
    11-14-2014 12:20 AM
  17. V J's Avatar
    Haven't had much issue but yes it's harder to get off compared to other cases, which is a good thing to me it lets me know that it's snug. Try gently but firmly pressing both thumbs against the back of the case so as to "push out" the phone while your other fingers "peel off" from the lip. Just do it gently so it doesn't pop right out.
    11-14-2014 03:39 AM
  18. alist_air's Avatar
    i bought that case for my wife... very nice..
    11-15-2014 01:27 AM
  19. GPtimes2's Avatar
    Here are the Samsung case and the Caseology together. The Samsung is less slippery and smaller. A 16th slimmer, same length, and rounded corners, make it seem dramatically so.
    Attached Thumbnails Best thin case for Galaxy Note 4?-uploadfromtaptalk1416047971679.jpg   Best thin case for Galaxy Note 4?-uploadfromtaptalk1416048126646.jpg
    11-15-2014 04:43 AM
  20. GPtimes2's Avatar
    Don't know how that last pic turned upside down. Here is one more.
    Attached Thumbnails Best thin case for Galaxy Note 4?-uploadfromtaptalk1416048631135.jpg
    11-15-2014 04:51 AM
  21. comfortably nub's Avatar
    Do those metal cases kill the signal at all? I am guessing the little white things around the phone are for reception and those seem to cover the crap out of them. The sammy case looks really nice, might look in to that one
    11-15-2014 11:20 AM
  22. zmann's Avatar
    I have already bought several cases but this is the one im using. It's rubber so no scratching the phone,, so thin and clear.
    NOTE 4,, GO BIG OR GO HOME!
    plumcrazy and sorosh AM like this.
    11-15-2014 11:50 AM
  23. tester2013's Avatar
    As with some cases...does this make the device look bigger (bulkier is the term I think Im looking for)?
    Thanks
    11-16-2014 10:41 PM
  24. V J's Avatar
    Thanks
    It does but very subtle. Looks-wise it doesn't look any bigger, as in it looks slim and stylish, maybe because the case is so streamlined. But you will definitely feel the added thickness in your hand.
    11-16-2014 10:51 PM
  25. solotristan88's Avatar
    The Ringke Slim is the best!!! Covers the corner that most slim ones leave bare and exposed....look it up. Got in on amazon!
    11-16-2014 11:20 PM
131 12345 ...
  1. Replies: 3
    Last Post: 11-14-2014, 09:23 AM
  2. Why won't my Galaxy Pro 8.4 not recognize my S4?
    By mrkeeko in forum Ask a Question
    Last Post: 11-12-2014, 02:39 PM
  3. Replies: 1
    Last Post: 11-11-2014, 03:31 PM
  4. Gear Live, Gear S, or Moto 360 for Note 4?
    By ProtoformX in forum Ask a Question
    Last Post: 11-11-2014, 12:33 PM
