02-21-2015 10:59 AM
131 ... 23456
tools
  1. tester2013's Avatar
    The Ringke Slim is the best!!! Covers the corner that most slim ones leave bare and exposed....look it up. Got in on amazon!
    It doesnt make the device look bigger does it?
    11-17-2014 10:27 AM
  2. cjb44's Avatar
    I went with the Otterbox and it's durable and thinner than I thought it would be.
    11-17-2014 02:21 PM
  3. ShadoWolf_TA's Avatar
    I second the vote for the Tech21 brand. I have been a die-hard Otterbox supported until I had a chance to check one of these out. The guys at the store were putting their Note 4s in them and tossing them around the room. After getting to look at one, see how good of a fit it was, how tight the case is, the durability and material, reinforcement on the sides, etc, I was sold.
    Attachment 147557Attachment 147558
    What screen protector are you using?
    godzillinois likes this.
    11-18-2014 11:21 AM
  4. godzillinois's Avatar
    Don't know how that last pic turned upside down. Here is one more.
    Wait, what is that Samsung labeled case on the left?
    11-18-2014 01:16 PM
  5. godzillinois's Avatar
    Is this still considered a 'slim' case? It looks great either way! I just ordered the UAG case but haven't received it yet - wish I saw this case before I ordered! I missed it since it's not in Amazon yet, is there enough grip/texture on the back/sides or is the case a little slippery?
    11-18-2014 01:18 PM
  6. magichoward's Avatar
    Just ordered
    http://m.ebay.com/itm/390959706206?_mwBanner=1
    Looks good, thin, light with grip
    11-18-2014 11:54 PM
  7. GPtimes2's Avatar
    Here is a link, I think it is Samsung's OEM product.
    Galaxy Note ® 4 Protective Cover, BLUE
    It comes with blue or black.
    It is about as thin as you can get and have a small lip for the front screen and rear camera. to protect it while laying flat. The website photo makes it look a bit bigger/thicker than it actually is. Not sure how much drop protection it will provide, but it would be some.
    11-19-2014 04:57 AM
  8. RS08's Avatar
    $12.99 from Amazon. I love it for the price.
    What screen protector do you have and where did you get it? Who is your carrier as I have read some SP fit phones differently?
    11-19-2014 11:10 AM
  9. gonzoks's Avatar
    Its super thin, hugs the phone real tight - ZERO gaps anywhere. Has reinforced sides (Ill try to take a picture later to show that part of it off). It has just the right amount of grip. I gauge this by placing it on the passenger seat in my car (leather) and driving around town. If it doesn't slide around, it's golden. This one doesn't move much.
    11-20-2014 11:07 AM
  10. gonzoks's Avatar
    Some 'self healing' jobbie from the same company. So far it refuses to scratch. It has a bit of an odd feeling to it - almost like its thick plastic - you can literally push on it and feel it give. However, it is crystal clear and has zero input problems with either my fingers OR the stylus. Again, I highly recommend these guys. I have always been an Otterbox fan, but not so much now.
    11-20-2014 11:09 AM
  11. godzillinois's Avatar
    Is it hard to take off and put on? That's my only gripe with the UAG case.
    11-25-2014 01:00 AM
  12. micktwo's Avatar
    that's exactly what I want
    11-25-2014 03:34 AM
  13. doohsun's Avatar
    funny i order the same one still waiting for it.
    Nillkin Amazing Armor Frame Border Bumper Case for Samsung Galaxy Note 4 N9100 | eBay but in red.
    i'm currently using UAG very rugged if you looking for something more durable doesn't look the prettiest but the best for durability.
    11-25-2014 12:51 PM
  14. Hectorius's Avatar
    https://forums.androidcentral.com/e?...token=YLLRU0So
    Enough said...
    Posted from the one and only... Note 4...
    11-25-2014 01:11 PM
  15. sparker04's Avatar
    ive been eyeing this one. ~$13 on Amazon
    magichoward likes this.
    11-26-2014 03:36 PM
  16. JayNote's Avatar
    Have a Spigen neo hybrid, Looks and feels great but adds a bit of weight and a slight extra width/bulk. Actually use it with dust plugs for the headphone and charging ports, May seem like overkill but I work in a warehouse/diy environment which can get quite dusty! Was never fun poking out dust from my old S3.
    Received my Rinkge Fusion today, Love it! Very slim and and well fitting, Adds hardly any noticable bulk, With dust flaps for the headphone and charging ports, Win! Also to whom asked if the Neo Hybrid scratches the phone, No it doesnt. I think only the hard cases cause scratches not the TPU/rubbery ones.
    11-26-2014 07:10 PM
  17. gonzoks's Avatar
    Not bad at all. Takes 5-6 seconds. Stays put. So far, so good.
    12-01-2014 10:47 AM
  18. MightyMike's Avatar
    Many great suggestions here. I use the $20 caseolgy case off Amazon. Good snug fit, Nice looking metal band, bumper, and leather texture on back for easy grip. I Love it, looks great and inexpensive. When this one wears out, I will get another.
    Posted via the Next Big Thing, My Galaxy N4
    12-02-2014 01:03 PM
  19. weave majjik's Avatar
    Galaxy Note 4 Case, Maxboost® [Clear Cushion] Galaxy Note 4 Cas... http://www.amazon.com/dp/B00NAHOHFO/...cUvbUpU4102806
    Super thin profile and coverage around the edges. Rubber edges don't scratch the phone and the polycarbonate back protects the phone from normal wear and tear. Does not seem to be a drop friendly case, but I'll take my chances for the slim profile. Also, fits the VZW Note 4 perfectly.
    thetaylor310 likes this.
    12-04-2014 01:26 AM
  20. clue1972's Avatar
    Can't beat the protection of an otterbox defender series. Worth every penny
    12-04-2014 01:45 AM
  21. godzillinois's Avatar
    I doubt that the Defender could ever be considered a "thin" case
    Thegreatone3 likes this.
    12-04-2014 12:11 PM
  22. yeatzee's Avatar
    unfortunately the majority of these will not work for your NOTE 4 if you have it from Verizon. way to screw us verizon. they said the reasoning for moving the microphone on the bottom over slightly was they thought it was a better design for function but that means you have to buy your case from them to get the mic holes to line up right.
    The majority of these have been updated with an elongated hole to make room for the verizon model.
    12-04-2014 02:04 PM
  23. Rick76's Avatar
    I am using the Ringke FUSION clear case. Yesterday my phone slipped off the roof of my car and CRASH onto the asphalt! Result = barely a mark on the case and no damage to the phone. Ringke wins.
    01-23-2015 12:22 PM
  24. Brian McMahon's Avatar
    Anybody using a wireless charging cover with a case, just wondering how good the connectivity will be with a case installed
    01-23-2015 06:17 PM
  25. brad419's Avatar
    I go for the Ringke SLIM case. Hardly know it is there, and is very good in the hand, not slick at all.
    01-23-2015 10:54 PM
131 ... 23456
  1. Replies: 3
    Last Post: 11-14-2014, 10:23 AM
  2. Why won't my Galaxy Pro 8.4 not recognize my S4?
    By mrkeeko in forum Ask a Question
    Last Post: 11-12-2014, 03:39 PM
  3. Replies: 1
    Last Post: 11-11-2014, 04:31 PM
  4. Gear Live, Gear S, or Moto 360 for Note 4?
    By ProtoformX in forum Ask a Question
    Last Post: 11-11-2014, 01:33 PM
