02-21-2015 09:59 AM
131 ... 3456
tools
  1. pappcam's Avatar
    01-23-2015 09:59 PM
  2. dedhedAndy's Avatar
    I have the otterbox symmetry on my note 4 and love it. I first got the commuter, had it on for a few weeks. Was a bit too bulky and I found it rather slippery to hold. the symmetry is great it feels so much better in my hands. The plastic has a better grip and the rubber is more exposed around the edges. I'm able to grip the rubber when picking it up quickly or just holding it.
    Love it love it love it!!
    Posted via Galaxy Note 4
    01-23-2015 10:10 PM
  3. rabernet's Avatar
    For the two weeks I had my Verizon Note 4, my favorite case was the Verus Thor. They have modified them to work with Verizon. I had contacted them prior to buying a color that didn't specify Verizon and since they fulfill the orders from Amazon, they told me to send them the order number and they'd make sure to ensure I got the Verizon modified case. LOVED that case so much it was one reason that I almost didn't exchange my phone for the Note Edge (the phone I really wanted at the time I upgraded and Verizon released 2 weeks later) . I now have three different colors of the Verus Thor for my Note Edge. While not the thinnest case, it's thinner than the Otterbox Commuter, and feels great with similar protection. I also love that their access to the heart rate monitor has the slope like the Otterbox. It's also one of Flossy Carter's highly reviewed cases (though I found that out after I already fell in love with them).
    01-24-2015 07:05 AM
  4. anon67808's Avatar
    I had Spigen Neo Hybrid. Got it like a week after I got my phone. Had it in that case for two months. Loved the look, fit, and protection. Needless to say, like many others have witnessed, it scratched the **** out of the aluminum sides of the phone.
    Recently bought a genuine Samsung protective case. It feels a lot slimmer than the Neo Hybrid and to my knowledge, offers similar protection. Been in this case for a couple weeks and haven't noticed any more scratching. I've also read from others that this case doesn't scratch the aluminum.
    01-24-2015 12:35 PM
  5. anon67808's Avatar
    Anyone with a Ringke Fusion clear case, how is it doing with the phone's aluminum sides? Any scratching?
    01-24-2015 12:43 PM
  6. dlgus's Avatar
    unfortunately the majority of these will not work for your NOTE 4 if you have it from Verizon. way to screw us verizon. they said the reasoning for moving the microphone on the bottom over slightly was they thought it was a better design for function but that means you have to buy your case from them to get the mic holes to line up right.
    Got my Note from Verizon, got mt case from Accessory Geeks...fits perfectly.
    Posted via the Android Central App on my AMAZING Note 4
    01-24-2015 05:36 PM
  7. Haalcyon's Avatar
    Tech 21 Tactical. I love Tech 21 cases.
    01-24-2015 07:38 PM
  8. PurseCrayons's Avatar
    I snagged a Ringke Slim case for $5.00 & free shipping! I just got it today & I'm in LOVE!! It's very slim & light weight!! I had been using a rubber/gel clear case which as soon as I'd get home I'd take it off! I just didn't like the way it felt! But this Mint color Ringke Slim will be staying on awhile, unless I need the pink one! Lol
    01-28-2015 05:26 PM
  9. asianguy80's Avatar
    I have the fusion and if you get dust trapped between the bumper area it will scratch the aluminum frame. It has done it to my VZW note 4
    01-31-2015 01:03 PM
  10. Infernalblaze's Avatar
    I am someone who loves thin cases and I just got a tech 21 case and love it. It's slim and sleek. Would def recommend giving it a try
    01-31-2015 04:14 PM
  11. Haalcyon's Avatar
    Tech 21 is up there at the top. They make a consistently great product.
    01-31-2015 05:42 PM
  12. Infernalblaze's Avatar
    yes I was torn between the Tech 21 and the Otterbox because in the past Otterbox has won. But this time I def love the protection of this case and the slimness
    01-31-2015 09:01 PM
  13. godzillinois's Avatar
    Tech21 iBand: Serious impact protection:
    02-01-2015 01:31 AM
  14. zaydabarber's Avatar
    Great case not bulky
    at&t note 4 & Gear 2
    Attached Thumbnails Best thin case for Galaxy Note 4?-screenshot_2015-01-31-19-48-30.jpg
    bdgriff likes this.
    02-01-2015 09:53 PM
  15. Dusty Morrow's Avatar
    I just bought the tech 21 case for about 50 dollars. I completely forgot about the verizon issue. Did i just wast 50 bucks?? :/ Will the mic still work on the verizon note 4 with this case i bought. I bought it directly from tech21, because i needed the clear one. Thanks!
    02-05-2015 04:05 PM
  16. Haalcyon's Avatar
    If it doesn't work for your phone I'll be happy to buy it from you.
    from the °4°
    Dusty Morrow likes this.
    02-05-2015 05:28 PM
  17. Dusty Morrow's Avatar
    Cool, Haalcyon i will sell it to you cheaper than i bought it, if it doesn't work. It is coming from across the pond, so it will take longer than i want it to for it to get here haha!
    02-05-2015 07:19 PM
  18. Infernalblaze's Avatar
    This might sound stupid but I'm guessing you didn't buy it from a verizon store lol
    02-05-2015 07:27 PM
  19. Dusty Morrow's Avatar
    Lol apparently i should have. I just bought the frosted white note 4 yesterday (should be getting it today) so i wanted the clear one. I am ocd about things matching lol. Verizon did not have the clear one, if my phone was black i would have gotten the other colors.
    02-06-2015 09:34 AM
  20. zaydabarber's Avatar
    Just order it
    Attached Thumbnails Best thin case for Galaxy Note 4?-screenshot_2015-02-11-13-27-01.jpg   Best thin case for Galaxy Note 4?-screenshot_2015-02-11-13-25-36.jpg   Best thin case for Galaxy Note 4?-screenshot_2015-02-11-13-26-20.jpg   Best thin case for Galaxy Note 4?-screenshot_2015-02-11-13-27-14.jpg
    02-11-2015 03:52 PM
  21. hamsterwheel's Avatar
    Using the Ringke slim and love it. Slim the gold looks great with my white phone. Also have the caseology which haven't tried yet. Just got it.
    02-13-2015 09:42 PM
  22. kami8586's Avatar
    If you don't prefer bulky. I believe the caseology case makes the phone seem very square
    02-14-2015 05:49 AM
  23. Haalcyon's Avatar
    The phone is very square though...in all its supreme awesomeness.
    • 🍎 iPhablet 6+ 🐛 •
    02-14-2015 06:21 AM
  24. Haalcyon's Avatar
    Bump
    🍎 iPhablet 6+ 🐛 •
    02-14-2015 06:22 AM
  25. jdotcarter's Avatar
    Samsung wireless charging back, Baseus aluminium bumper and the iCarez screen protector is pretty bad arse and I feel ultimately protected.
    Attached Thumbnails Best thin case for Galaxy Note 4?-5143.jpg   Best thin case for Galaxy Note 4?-5142.jpg
    para4175 likes this.
    02-14-2015 02:14 PM
131 ... 3456
  1. Replies: 3
    Last Post: 11-14-2014, 09:23 AM
  2. Why won't my Galaxy Pro 8.4 not recognize my S4?
    By mrkeeko in forum Ask a Question
    Last Post: 11-12-2014, 02:39 PM
  3. Replies: 1
    Last Post: 11-11-2014, 03:31 PM
  4. Gear Live, Gear S, or Moto 360 for Note 4?
    By ProtoformX in forum Ask a Question
    Last Post: 11-11-2014, 12:33 PM
