1. BigCrimsonTX's Avatar
    I just ordered my wireless charging back and wireless charging pad for my Note 4. What should I know so I can maximize this set up?
    Thanks in advance.
    11-13-2014 02:07 PM
  2. kalinskym's Avatar
    Two things
    1. It will not charge as fast as fast charging unless the current meets the same standard
    2. Where! I want one, I live in the UK
    Can't wait for Intel charging bowl for all my gadgets
    11-13-2014 02:19 PM
  3. Rukbat's Avatar
    Find the "sweet spots". You have to position the phone just right on the pad, but there are a few spots. Mine is usually about 1/4" below the bottom edge of the pad and about 1/2" to the right of it. There's also one with the phone across the pad. That way you can just drop the phone on the pad without having to fumble until you find the right spot. (It should charge just a little bit faster than the USB port on your computer - USB charging is 450mA, wireless is about 600mA and AC charging is about 1,200mA.)
    Get a good wifi or Bluetooth file transfer app. Get wireless adb and wireless Kies. Then if your microUSB port breaks, you can take your time getting it fixed - you can do just about everything wirelessly.
    (If you really want to get fancy, spring the $3 for Tasker and learn how to use it, so your lock screen unlocks and mobile data is off when you get home and USB debugging is off when you're out. And GPS and wireless data turn on automatically when you run your GPS route app.)
    BigCrimsonTX likes this.
    11-13-2014 02:30 PM
  4. iGalione's Avatar
    wirless Kies still works? hasn't worked for me since the Note 3
    11-14-2014 12:48 AM
  5. ReggieTee's Avatar
    They sent me the wireless charging back for the Note 3 when order form clearly says Charcoal N4. Will be calling them in the morning.
    11-14-2014 01:35 AM
  1. Screen sometimes recognizes only my S Pen, not my hand?
    By Space Bananas in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 11-17-2014, 06:51 PM
  2. White spots on the back of my M8
    By Bajwa2307 in forum HTC One M8
    Last Post: 11-17-2014, 08:39 AM
  3. My pre-order has shipped!
    By Vinnyjb in forum Samsung Galaxy Note Edge
    Last Post: 11-16-2014, 10:01 PM
  4. Samsung EVO 64gb sdxc
    By digger951 in forum Samsung Galaxy Note 4 Accessories
    Last Post: 11-14-2014, 08:42 AM
  5. Replies: 1
    Last Post: 11-13-2014, 02:49 PM
