12-05-2014 09:49 AM
30 12
tools
  1. harryhoudini66's Avatar
    That is correct. In my case, I already had the two of them and used them for my iBolt setup. Consider it an investment. While the actual device holder may change as you get a new phone, the dash mount and ball will not.
    12-04-2014 11:44 PM
  2. harryhoudini66's Avatar
    Here you go.
    Attached Thumbnails Car Dock for Large Phones using ProClips USA and Ball Mount-iottie.jpg
    12-04-2014 11:47 PM
  3. leerandall's Avatar
    Here you go.
    You're the man, Harry. Thank you.
    12-05-2014 12:24 AM
  4. Evilnut's Avatar
    I have been using this mount for quite some time now. I use it to hold my phone in my truck and transfer it to my motorcycle to hold my GPS too.
    Ram Mount Cradle Holder for Universal X-Grip Cellphone/iPhone with 1-Inch Ball - Non-Retail Packaging - Black https://www.amazon.com/dp/B0055PH0XA...cUvbUpU4105280
    They also make a larger one that may work better for a phone the size of the Note 4.
    Ram Mount Universal X-Grip IV Large Phone/Phablet Holder with 1-Inch Ball - Non-Retail Packaging - Black https://www.amazon.com/dp/B00C7B2NV4...cUvbUpU4105280
    This is the suction cup mount I use in my truck. I have a handlebar mount for my motorcycle.
    Ram Mount RAM-B-166U Double Ball Twist-Lock Suction Cup Mount https://www.amazon.com/dp/B002IV6OHC...cUvbUpU4105280
    It is rock solid and does not move at all while I'm driving even in my truck with its firm 4X4 suspension. I also have a Ram tablet mount that hooks onto the suction cup mount and I use it to hold my Nexus 10.
    Posted via a beautiful Ebony backed Moto X on Verizon or the amazing Nexus 10 using the Android Central App
    12-05-2014 12:50 AM
  5. mty msi's Avatar
    The dash mount changes as you change vehicles but the ball and universal device holder (whether it's Proclips or iOttie) would stay the same. The fact that the Proclips mount is designed to fit a particular vehicle and fits into the dash panel seams is I think it's most attractive feature. I don't want my phone mounted on top of the dash, the vents aren't stable enough to use as a mounting base and that leaves very few places that have enough room to mount a suction cup. I like the Proclips side of console mount.
    12-05-2014 09:49 AM
30 12
  1. Verizon phone with most egregious carrier branding?
    By Jordan Miera in forum Verizon
    Last Post: 12-04-2014, 10:45 AM
  2. stock recovery for tabpro 8.4 on 4.4.2
    By mashhud1 in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 12-02-2014, 09:11 PM
  3. Hello from Appleton, Wisconsin, USA
    By JeffWeber in forum New to the Forums? Introduce Yourself Here!
    Last Post: 11-30-2014, 02:49 PM
  4. Replies: 1
    Last Post: 11-28-2014, 06:23 PM
  5. Google Nexus 6 No Phablets On Sale for Black Friday
    By RealDogBoy in forum Google Nexus 6
    Last Post: 11-28-2014, 06:02 PM
