1. rgrim's Avatar
    Anybody aware of a case that will fit a Verizon Note 4 with the wireless charging back cover fitted? It makes the phone just a little thicker than the normal back cover, enough so that most bumper style (or other I'm sure) cases will not fit.
    12-06-2014 03:31 PM
  2. ericandjan's Avatar
    When I first bought my Note 4, I bought the Samsung billfold style case (cover flips open to the side), and I know that this case did have a wireless charging capability. I ended up returning the case for an Otterbox (without wireless charging) because the flip cover makes it all but impossible to use the phone with one hand for even simple tasks (I'm right handed). Plus, I did not feel all that confident that the case itself offered more than weak protection. Only the back of the phone was protected during a fall because there is no way to secure the flip cover, meaning that it could flop open during the fall and expose the screen to possible damage. The sides were also exposed in this case.
    12-11-2014 11:28 AM
  3. buffdaddy72's Avatar
    Only case I'm aware of is the wireless cover case made by Samsung. Also Samsung sells a wireless charging back cover replacement. I went with the back cover and bought an inexpensive metal bumper case off Amazon.
    12-14-2014 09:17 AM
  4. Derek Patterson's Avatar
    I have a note 4 and I have the wireless charging back fitted. I always use Tech 21 cases.
    If you purchase this case and warm it up using a hair dryer till its quite hot it will go on and fit like a glove!
    12-14-2014 09:19 AM
  5. rgrim's Avatar
    The wireless charging back cover is what I got. Which metal bumper case did you get from Amazon that fits?
    12-17-2014 10:06 AM
  1. Verizon LG G2 & MetroPCS
    By RekabSirhc in forum Verizon LG G2
    Last Post: 07-09-2015, 11:57 AM
  2. For how many hours i should charge my new htc one m8??
    By Alexandros1 in forum HTC One M8
    Last Post: 12-15-2014, 09:01 AM
  3. Replies: 1
    Last Post: 12-07-2014, 12:11 AM
  4. Notification sound continually for no reason
    By mty msi in forum Samsung Galaxy Note 4
    Last Post: 12-06-2014, 04:23 PM
