04-19-2015 09:49 PM
33 12
tools
  1. charleskoz's Avatar
    Can anyone recommend a car charger for the Note 4 that supports Quick Charge 2.0 / Adaptive Fast Charging?
    Priorities: Good quality, reasonable price, if possible availability on Amazon.
    Thanks.
    12-08-2014 12:09 PM
  2. felloffthetruck's Avatar
    PureGear, Incipio or the Verizon one with the lighted end. I've had them all and the Verizon is the one I use.
    12-08-2014 12:12 PM
  3. bharding08's Avatar
    I got the pure gear. Works great.
    12-08-2014 04:33 PM
  4. felloffthetruck's Avatar
    I put a couple pictures of the Verizon quick chargers in this thread:
    http://forums.androidcentral.com/sam...rger-pics.html
    12-08-2014 05:43 PM
  5. samwifi's Avatar
    My puregear car charger appears to have blown my fast charge circuitry on my note 4.. be careful.
    12-09-2014 06:28 AM
  6. felloffthetruck's Avatar
    How would you know this?
    12-09-2014 08:44 AM
  7. charleskoz's Avatar
    Thanks for the replies, appreciate it.
    12-09-2014 11:48 AM
  8. dpham00's Avatar
    I have the same one. Good quality. A bit pricey though I got a 25% employee discount.
    Sent from my Verizon Samsung Galaxy Note 4
    12-09-2014 02:47 PM
  9. sparksd's Avatar
    I got this one, too. Pricey but works great as a car Quick Charger.
    12-09-2014 04:50 PM
  10. charleskoz's Avatar
    Decided to order the official Samsung one, since I like OEM stuff when it has good reviews. I'll report back on how it works. Thanks.
    12-10-2014 08:15 AM
  11. felloffthetruck's Avatar
    Please post a link to this charger as I have not been able to find it. Thanks.
    12-10-2014 08:49 AM
  12. samwifi's Avatar
    Couple of days ago, I got back into my car and plugged my phone into the puregear xtreme and puregear white usb cable. The phone showed connected then disconnected over and over. I reinsert 3 times and could not get the phone to show it was charging.. seemed like a bad connection but it was plugged in all the way.. when I got home I tried on my standard samsung fast charger and while it worked, fast charge did not, even though my phone was at 28%. Fast charging has not worked since that incident and puregear will now connect but only standard charging. Puregear was very helpful and gave me a FedEx label to ship the product back. But, I'm still stuck with a phone minus one the key features I depend on.
    12-11-2014 06:15 AM
  13. charleskoz's Avatar
    The link is here: http://www.amazon.com/gp/product/B00...cUvbUpU4121610
    However, it does NOT support Samsung's fast charging despite the description, so it is going back and I'm back to the drawing board.
    12-12-2014 04:59 PM
  14. felloffthetruck's Avatar
    The link is here: http://www.amazon.com/gp/product/B00...cUvbUpU4121637
    Get the Verizon one, works great and even has the LED light on the micro USB end.
    12-12-2014 05:13 PM
  15. charleskoz's Avatar
    Anyone have the Powermod one? I know a lot of folks like the Verizon one but it's not on Amazon and I'm a Prime junkie. It's also overpriced.
    12-13-2014 02:14 PM
  16. felloffthetruck's Avatar
    You only get what you pay for.
    Saw someone on here saying that the Puregear car charger messed up the fast charge circuitry on his phone.
    12-13-2014 02:53 PM
  17. NVNJ's Avatar
    I have the power mod. No issues and works quite well.
    12-13-2014 03:54 PM
  18. charleskoz's Avatar
    True often, though the case I ended up keeping costs $10 and I liked better than two $25 ones.
    I don't care too much about the few extra bucks but Amazon is just more convenient. I'll try the Powermod and see how it goes.
    12-15-2014 06:43 AM
  19. harryhoudini66's Avatar
    I received the Powermod and it instantly died. I connected it and the light turned on for a second before it died. I got the Verizon Turbo charger and it works perfect. Shows as Adaptive Charging as well
    12-15-2014 08:19 PM
  20. charleskoz's Avatar
    Well, that's why I am biased towards Amazon. When that happens I click a few buttons and UPS comes pick up the old device and I order a new one.
    I'll report back on how it works. If it doesn't, I'll find the Verizon one somewhere local if I can.
    Thanks.
    12-16-2014 06:38 AM
  21. Rally Android's Avatar
    Why don't people get the Samsung OEM 2amp car charger instead? It's cheaper then Verizons.
    http://www.amazon.com/gp/aw/d/B00K7E...cUvbUpU4128187
    12-16-2014 09:47 AM
  22. felloffthetruck's Avatar
    http://www.amazon.com/gp/aw/d/B00K7E...cUvbUpU4128705
    Because it has no Qualcomm 2.0 fast charge capabilities
    12-16-2014 02:08 PM
  23. Rally Android's Avatar
    Yeah saw that at the end. Did find another one that is QQC 2.0 compatible though on Amazon, but it's almost the same price as Verizons one.
    12-16-2014 05:43 PM
  24. felloffthetruck's Avatar
    12-19-2014 10:19 AM
  25. charleskoz's Avatar
    Used the Powermod a few times, no issues so far.
    12-27-2014 11:54 AM
33 12
  1. Reason why LG G3 charges slowly...
    By TJWINS in forum LG G3
    Last Post: 04-29-2016, 01:54 PM
  2. Quick reply app
    By Ricky Hughes in forum Android Apps
    Last Post: 12-12-2014, 06:36 PM
  3. How do I add and use email quick responses?
    By McKayForbes in forum Ask a Question
    Last Post: 12-10-2014, 11:03 AM
  4. Battery Temp While wireless charging your G3?
    By fullcircle_bflo in forum LG G3
    Last Post: 12-08-2014, 10:13 AM
  5. email quick responses
    By McKayForbes in forum Samsung Galaxy Note 4
    Last Post: 12-08-2014, 07:09 AM
