1. jummybui's Avatar
    Hello All,
    I am trying to find a case that will work with the Samsung wireless Charging battery Cover. It is thicker than the standard battery cover.
    I have the following cases now and none of them work.
    Spigen Neo Hybrid Case
    Caseology TPU Case
    Ringke Slim Case
    Ghostek Bull Slim Armor
    Please help me
    12-25-2014 02:37 AM
  2. buffdaddy72's Avatar
    Nah, there is nothing out there right now case-wise to use with the wireless back cover. I ended up getting one of those aluminum bumper frames you can get on Ebay or Amazon for $7-$8 and it's not bad. Fits very nicely with the wireless back cover.
    Granted you won't get total protection but it looks nice.
    jummybui likes this.
    12-25-2014 12:01 PM
  3. jummybui's Avatar
    Thanks! Ill check out the bumper frame.
    12-25-2014 04:07 PM
  4. Derek Patterson's Avatar
    Get the tech21 case and warm it up with a hair dryer till its quite supple....then it will go on your phone!
    12-30-2014 12:51 PM
  5. jummybui's Avatar
    Thanks for the idea. Not sure if i want to spend $40 on a case just to do that. I may give it a try on the TPU Case I have
    12-30-2014 08:38 PM
  6. jummybui's Avatar
    With Derek Patterson's advice. I was able to get my Caseology TPU slim case to fit. Thanks for the Idea again!
    Btw the Heart Rate Monitor wont work right with the Wireless Charging battery cover and this case together.
    Link to the case i am using if anyone is wondering.
    http://www.amazon.com/gp/product/B00...cUvbUpU4156247
    DMarie04 likes this.
    12-31-2014 09:29 AM
  1. Replies: 9
    Last Post: 11-07-2017, 01:07 PM
  2. Galaxy S5 - can't change lock screen wallpaper?
    By lutalica in forum Samsung Galaxy S5
    Last Post: 10-12-2017, 02:04 PM
  3. Samsung Galaxy Note 4 Battery life today
    By currentdroiduser in forum Samsung Galaxy Note 4
    Last Post: 12-31-2014, 12:44 PM
  4. Replies: 4
    Last Post: 12-28-2014, 03:57 PM
