I got my samsung wirless cover today & read about no cases working with it, which none of my fit either. It was just a little bit so the case i"m using now a spigen capsule, is a thin tpu case. It was just a little to small witj the wireless cover so i put the case in the microwave for about 20 seconds give or take a few seconds a it made it just plyable enough to fit the edges around the lip of the phone. I've only had it on for a couple of hours but seems ok so far. I'm sure you could repeat process till it fits. The case was pretty warm but i put it on anyway but i guess you couls try strching it by hand then try it on. It will obviously only work on soft cases so i guess i'll store or sell my hard plastic cases but i feel its better than no case. If anyone trys it out post & let me know how it turned out for you.
