1. hamsplainer's Avatar
    I have a pair of Shure SE215 headphones with a wider than normal plug. The first couple of cases I've tried from Caseology and Diztronic can't accommodate the plug. Can anyone recommend a case with at least 1 cm of clearance in the headphone jack cutout?
    Thanks.
    01-14-2015 09:56 AM
  2. Rukbat's Avatar
    That's just under half an inch, so probably not. You'll have to get a TPU case and cut the hole wider. Thick cases (I suspect that's your problem) don't allow for half inch plug shells. (An Otterbox Defender might do it, because the earphone jack cover opens.)
    01-14-2015 10:29 AM
  3. MalinoisK9's Avatar
    The Spigen slim armor had a large opening as does the tech 21 tactical case. Neither are on my phone right now bet can get ya a measurement latter if you'd like. I have a friend who plays bass and all his cords do not fit his edge cases but worked with the 2 I mentioned.
    01-14-2015 11:48 AM
  4. Haalcyon's Avatar
    I have the Tech 21 Tactical on both my Notes. On the 4 I'd say the cutout is about a .6" x .3" x .25".
    01-14-2015 03:00 PM
  5. MalinoisK9's Avatar
    Don't have a way to get a good measurement of the size but perhaps this pic helps. Tech 21 tactical to the left slim armor right.
    Attached Thumbnails recommendation request: case with wide headphone jack cutout?-1421278339330.jpg
    01-14-2015 05:32 PM
  1. Chromebook pixel with LTE and 64GB flash storage
    By droidman2177 in forum Marketplace Archive
    Last Post: 02-04-2015, 05:07 PM
  2. Replies: 14
    Last Post: 01-22-2015, 03:07 PM
  3. Delete photo confusion with Nexus 5/Google+
    By tdellaringa in forum General Help and How To
    Last Post: 01-19-2015, 05:43 PM
  4. Why is my Samsung Note 10.1 (gt-n8010) really slow at charging?
    By Ahmeerkat in forum Samsung Galaxy Note 10.1
    Last Post: 01-15-2015, 08:25 AM
  5. Problem with focus when shooting a video.
    By tprisher in forum Motorola Droid Turbo
    Last Post: 01-14-2015, 10:40 AM
