1. kami8586's Avatar
    Are there any tripod mount adapters for the note 4? I like to shoot some videos and would be nice to have one! Thanks!
    04-08-2015 02:55 PM
  2. sparksd's Avatar
    http://www.amazon.com/s/ref=nb_sb_ss_i_1_13?url=search-alias%3Daps&field-keywords=note+4+tripod+mount&sprefix=note+4+tripod%2Caps%2C328
    I bought one of these:
    http://www.amazon.com/gp/product/B00MAARLT6/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    It has a tripod mount but also has a nice grip for stabilizing the phone for pictures or (primarily) video. Very well made and works great.
    Neo_ii_Droid likes this.
    04-08-2015 05:24 PM
  3. Neo_ii_Droid's Avatar
    Say, that ShoulderPod S1 Professional Smartphone Rig is something I may have to invest in. Thanks for that suggestion/link!
    04-08-2015 08:35 PM
  4. sparksd's Avatar
    It really does help to maintain stability. I use something similar (though larger handle) with a GoPro - for video it really helps.
    04-08-2015 10:32 PM
  5. kami8586's Avatar
    Thanks! The shoulder pod looked neat but I'll probably end up getting the adapter and just a medium sized tripod. Is for shooting r/c videos ☺
    04-08-2015 10:41 PM
  1. Why can't I mount /system rw?
    Last Post: 02-26-2016, 01:14 PM
  2. Can't mount anything in TWRP
    By alcaponed in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 05-18-2015, 06:46 AM
  3. Does anyone know where I can get a mount fix for my dl700 Lollipop rom?
    By Roshane Hall in forum Android 5.0 Lollipop
    Last Post: 04-09-2015, 10:03 AM
  4. iOttie Easy Smart Tap 2 Mount
    By Phantasmal Images in forum Samsung Galaxy Tab S 8.4
    Last Post: 04-02-2015, 07:12 PM
  5. Galaxy S 3 Failed to mount /system - How to get my data?
    Last Post: 04-01-2015, 06:32 PM
