1. zkyevolved's Avatar
    Hello! I thought I'd publish my review of the UAG case.
    I love this case! It's gorgeous, very protective and very well built.
    I took some pictures. Take a look at these:
    Urban Armor Gear (UAG) Case Review-wp_20150406_17_39_33_pro.jpgUrban Armor Gear (UAG) Case Review-wp_20150406_17_39_17_pro.jpgUrban Armor Gear (UAG) Case Review-wp_20150406_17_39_07_pro.jpgUrban Armor Gear (UAG) Case Review-wp_20150406_17_38_59_pro.jpgUrban Armor Gear (UAG) Case Review-wp_20150406_17_38_51_pro.jpgUrban Armor Gear (UAG) Case Review-wp_20150406_17_38_45_pro.jpg
    The feeling in hand is fantastic. Very firm, solid. It's obvious that it's well built.
    It's not that difficult to put on, but boy, taking it off does make me feel like I'm going to break my phone. Sometimes I don't know where to push / pull. 99% of the time, I end up taking off part of the battery cover.
    NFC works fine with the case on. I read in other forums and in this one that if you add a QI pad to the back, it also works fine. It fits very snugly, so I'm not so sure if it'll fit with the QI charging back (the entire replacement battery back), so I'd be wary of that.
    As you can see from the images, it does add bulk, which is fine. I used it for over a week consecutively without taking it off (not even once) to get a feel for it, and it's great. I love the case. This case is going to be in my permanent collection .
    One nice touch is that UAG threw in a screen protector. Now, the screen protector is slightly smaller than the actual screen, so that means that you'll see borders around the screen. The quality of the screen though is fantastic, so no problems in that department .
    Overall, the case is awesome. It's kind of expensive, but I spent a lot of money on my phone just to let it fall once and ruin the experience. The case offers a lip on the front (and obviously the back) so when I want better volume from the device I put it face down. If you look at the speaker though, there is a hole for it that is surrounded by a ridge that allows the sound to not be muffled and it actually sounds almost as good facing down with the speaker up in the air!
    So... Final thoughts:
    Good buy I'd recommend it. Just beware: it does add bulk to your phone.
    05-03-2015 09:21 AM
  2. Neo_ii_Droid's Avatar
    Thanks for your POV on the UAG Outland. I have no regrets whatsoever purchasing mine and using it and I do find that it is "perfect" for the SGN.IV and for what it was intended for. I've posted my at-a-glance here: http://forums.androidcentral.com/sam...o-you-use.html
    Anyways, enjoy!
    05-03-2015 05:01 PM
  3. zkyevolved's Avatar
    Anyways, enjoy!
    Thanks! I'll post up in that thread as well
    05-04-2015 01:54 AM
  4. Brian Kenny's Avatar
    I have the maverick (the clear one) and I love it... solid case
    05-04-2015 08:37 PM
  5. rem0us's Avatar
    I had a UAG on my note 2. Dropped the phone once and screen shattered. Got the Defender for my note 4. Sure it adds bulk but the protection it gives is well worth it.
    05-05-2015 09:44 PM
  6. zkyevolved's Avatar
    I suppose you're right. If you don't mind me asking, how did you drop it? I mean, on what surface, at what height, and what did it land on (as in screen, edge, back)?
    I really think that this case is more than enough for the majority of the people...
    Neo_ii_Droid likes this.
    05-06-2015 01:50 AM
  7. Neo_ii_Droid's Avatar
    I'm supposing that if any cell phone were to be dropped on its face (screen) on hard uneven surface(s) the screen may more than likely crack and, in my opinion, not due to the case itself. Here's one drop test on a Samsung Galaxy S5 (not Samsung Galaxy Note 4):
    zkyevolved likes this.
    05-06-2015 09:58 AM
  8. rem0us's Avatar
    I pulled it out of my pocket, so about waist high. it fell on concrete..
    05-27-2015 09:45 AM
  9. Mark Morrison's Avatar
    Thanks for the review.
    I bought the clear ice case, based on a few reviews. It doesn't do the job for me, due to three factors.
    1 - Couldn't get the case to align properly with the volume rocker.
    2 - The thickness it adds on the sides is enormous. It wouldn't fit it my iOttie XL phone holder. Deal killer.
    3 - The case, as mentioned, is extremely difficult to remove.
    So if someone wants a permanent installation and has better luck with volume rocker fit, it's an ideal case.
    06-06-2015 07:10 PM
  10. Neo_ii_Droid's Avatar
    Interesting. This is the first I'm reading about. Have you any pictures that you can provide of the entire case on your Note 4 to show this?
    "Extremely difficult to remove"? That's rather subjective.
    06-07-2015 12:01 AM
  11. zkyevolved's Avatar
    No no. It's near impossible without having the feeling like you might break your device along the way xD. Maybe you can find a review that says otherwise like... "an easy case to remove" or "removed with ease" haha.
    Sent from my SM-N910F using Tapatalk
    06-07-2015 02:07 AM
  12. Mark Morrison's Avatar
    No pictures. I wouldn't try to mislead anyone, though. I've gained plenty of knowledge from people here, I'm just giving my impressions.
    I went back to my thin $1 tpu cases from eBay to keep the slim profile, but may try the Cruizer BugDroid cares next. I'm happy that you and many others like this case. It's very high quality.
    06-07-2015 08:40 AM
  13. MizWylie's Avatar
    The trick with UAG cases on any phone (I've had them on three different iPhones, a S5, a Note 3 and now my Note 4 (man I should invest in stock), is to pull back and push on one corner, once the corner is relatively free slide your thumb down the side just under the lip from the corner you released and push gently from the back at the same time. Your phone can take it, I promise. I have as of yet to destroy a phone using a UAG.
    Sincerely,
    A UAG veteran
    huntnyc likes this.
    06-30-2015 01:19 AM
  14. Alex Wetzel's Avatar
    I absolutely love my UAG case for my note 4. It's taken some nasty drops without fail, and it looks really good too!
    Posted from the one and only Note 4
    huntnyc likes this.
    10-24-2015 05:42 PM
  15. Rocko's Avatar
    I love UAG. I use is on all my phones.
    11-06-2015 06:52 PM
  16. RC51 RIDER's Avatar
    I just received my UAG case today for my Note 5 and it came with a tempered glass . I've been using this company for yrs and it has great grip , doesn't add that much bulk and is bullet proof if you drop your phone !
    11-13-2015 07:26 PM
  17. PublicImageLtd's Avatar
    Looks rather bulky to me?
    11-17-2015 11:59 AM
  1. Case or Naked?
    By boogas8 in forum Samsung Galaxy S6 edge
    Last Post: 05-18-2015, 05:06 AM
  2. Screen protectors vs case
    By Jesse Edelstein in forum Google Nexus 5
    Last Post: 05-17-2015, 08:16 AM
  3. Certain apps not sending notifications to my LG Urbane
    By batnip in forum LG Watch Urbane
    Last Post: 05-05-2015, 01:24 AM
  4. Any scratching on back glass from cases?
    By atkjhi in forum Samsung Galaxy S6
    Last Post: 05-02-2015, 09:44 PM
  5. Is there a way to get my disney experience on the gear s?
    Last Post: 05-02-2015, 02:12 PM
