1. abelmosh's Avatar
    I bought a LED flip cover for my note 4 but I have a problem setting the notifications on the cover. They currently just appear randomly so and the information is not correct. I watched to know how to set it up in a way that it will show me when I have notification. please help.
    05-09-2015 12:54 PM
  2. Princepia's Avatar
    It should just work. There is no set up. It will show spinning circles for most notifications. It will show texts if using stock messenger app, email if using stock, phone calls. And some other random animations like when you are listening to music, or turning up the volume.
    05-10-2015 02:44 AM
  3. Duncan Annetts's Avatar
    My LED case permanently does the 4 swirling dots whether I have a notification or not. The only time it shows anything else is when I have one of the primary notifications or if it is showing battery level/time etc.
    I'm on Vodafone in the UK running KK 4.4.4 . I get this when using either Touchwiz or Nova.
    Just the ability to turn off the "Other" notifications would be good enough, but setting up what notifications it'll swirl for would be better. The ability to design your own dancing LEDs would make it perfect.
    I feel a bit short changed at the moment.
    05-15-2015 06:50 AM
  1. Thinking Of Switching To The Note 4 - Pros and Cons, Please
    By millerwa76 in forum Samsung Galaxy Note 4
    Last Post: 05-14-2015, 08:31 AM
  2. Replies: 3
    Last Post: 05-11-2015, 12:35 AM
  3. How do I transfer photos from Google plus to samsung galaxy 6
    Last Post: 05-10-2015, 01:37 AM
  4. how do i root my android galaxy s5
    Last Post: 05-10-2015, 12:15 AM
  5. How do I root a Samsung Core Prime?
    Last Post: 05-09-2015, 12:52 PM
