If i use a rapid charge cable with my note four do you think it will fry the port because of the already built in quick charging capability.
The device will only charge as fast as it supports. I wouldn't worry about the charge ports frying, but will still recommend using a charger that is supported by the device and/or rated for it as well.If i use a rapid charge cable with my note four do you think it will fry the port because of the already built in quick charging capability.
