1. Snoflo's Avatar
    Hi everyone,
    I'm in a bit of a quandary: I swap batteries almost daily on the Note 4 but I would like to keep the phone in a protective case as well. The Caseology one I have is a bit of a nightmare to remove and I have suspicions that the case scratches the metal rim on the phone too.
    Can anyone suggest a phone case for frequent battery swappers? Or is going naked the best way (which is what I do now)? Thanks folks.
    08-16-2015 05:43 PM
  2. Rukbat's Avatar
    I prefer the Otterbox Defender cases. (I wouldn't drive over one, but it feels as if it should almost take it.) I've dropped my phone a few times now, and the case has saved it.
    But it is a royal pain to remove it to change the battery - which I only do monthly.
    I haven't found any really solid case that's easy to use if you change the battery. (And going naked isn't something I want to do unless absolutely necessary. Even my cheap spare phone is in a belt pouch that's worth about as much as the phone.)
    Snoflo likes this.
    08-16-2015 05:59 PM
  3. Snoflo's Avatar
    Thanks, Rukbat. The search continues!
    08-16-2015 06:15 PM
  4. dedhedAndy's Avatar
    I use an otterbox symmetry and swap batteries daily. It's real easy takes >1min to swap. The symmetry protection seems good to me. I've dropped the phone a few times from waist high with no problems.
    Posted via Galaxy Note 4
    Snoflo, Rocko, cinnamin and 1 others like this.
    08-17-2015 11:38 AM
  5. Snoflo's Avatar
    Wonderful! I will check both of these options out. Thanks much.
    08-17-2015 03:49 PM
  6. Snoflo's Avatar
    Thanks, bought both.
    08-17-2015 07:02 PM
  1. Replies: 2
    Last Post: 08-30-2015, 06:02 AM
  2. Replies: 2
    Last Post: 08-16-2015, 01:29 PM
  3. Why does screen use 48 of battery?
    Last Post: 08-16-2015, 11:10 AM
  4. Replies: 0
    Last Post: 08-16-2015, 05:53 AM
