1. Sammiller88's Avatar
    I like to buy a charging case but don't know what to go for
    Can anyone recommend a good charging case
    12-19-2015 02:58 AM
  2. ChetManley762's Avatar
    I use the Caseology Envoy case. It will fit tightly but works well. I did need to use a dremel tool and grind a little bit around the charging port area so I could plug it in when I needed to. Also the Samsung Galaxy Note 4 N9100 Border Bumper Case, Slim Armor Border Shockproof Bumper Frame Case Cover will fit as well. I use both alternately. Both cases can be bought on Amazon. Hope this helps, I had a devil of a time finding cases that fit!
    12-22-2015 09:39 PM
  1. Note 3 not charging or staying charged :(
    By LindleyRDH in forum Samsung Galaxy Note 3
    Last Post: 12-19-2015, 06:44 PM
  2. help me with battery drain
    By Sammiller88 in forum Samsung Galaxy Note 4
    Last Post: 12-19-2015, 02:42 PM
  3. Replies: 2
    Last Post: 12-19-2015, 02:47 AM
  4. Memory Help.
    By Overloaded13 in forum Ask a Question
    Last Post: 12-19-2015, 01:04 AM
