1. ADACL's Avatar
    Hi there. I just recently purchased a battery for my Note 4. Was having issues with the battery that came with the phone so I figured I should buy a spare one. Ad was stating it as a legit product, saying original Samsung blah blah blah. Issue with this is the battery does not charge to 100%, only to 85%. I noticed this in the morning when I woke up ( phone was left on charge over night ). I didn't touch my phone at all in the morning until I got to work. When I looked at my phone, from 85%, it dropped to 73%. I have already contacted the person who I ordered it from, just waiting for a response. Is this normal, I'm I doing something wrong, or is the product defective?? Any advice or help is appreciated. Thank you
    04-12-2016 07:54 AM
  2. spagman's Avatar
    You're doing nothing wrong, Unfortunately if you don't purchase a battery from a reputable store like best buy or a carrier store...... You are more than likely going to get a cheap counterfeit.
    Ask for your money back.
    You should also look into Anker batteries.
    04-12-2016 04:01 PM
  3. Rukbat's Avatar
    Try http://www.amazon.com/Battery-Anker-...cUvbUpU5123428 Good company and I've never had any problem with any of their products.
    huntnyc likes this.
    04-13-2016 05:42 PM
  4. paulrf072894's Avatar
    I had the same issue when I first used a replacement battery. But once I let it die, I recharged it and it went to 100%
    You may have received a defective battery or a used one
    08-19-2016 10:23 PM
  5. dlcpa's Avatar
    Anker is super reliable! I don't know anyone there but I had a problem with one of their batteries and they couldn't have been nicer and more responsive. I'm going to get Ankers for the Note 4 I'm buying in a few minutes.
    huntnyc likes this.
    09-01-2016 02:43 PM
  6. rtwright68's Avatar
    Geez, I guess I waited to long to purchase. Nothing in stock for the Note4 from Anker on Amazon now. No batteries or the two battery/charger option. Hope they come back!
    09-20-2016 02:26 PM
  1. transfer contacts from old galaxy ace to galaxy S4?
    Last Post: 04-13-2016, 05:47 PM
  2. Replies: 1
    Last Post: 04-12-2016, 09:13 AM
  3. Replies: 1
    Last Post: 04-12-2016, 07:00 AM
  4. Forget the screen lock pin for Samsung gt i8262 phone
    Last Post: 04-12-2016, 05:47 AM
  5. Galaxy Core Prime - Can't remove Virus!
    Last Post: 04-12-2016, 04:16 AM
