1. nuraman00's Avatar
    I just noticed this yesterday.
    If I do a normal voice call, my microphone works.
    If I try joining a WhatsApp or Zoom call, my microphone doesn't seem to work. When I join a Zoom call, for example, the microphone symbol doesn't seem to fluctuate when I talk. Normally the microphone symbol in Zoom fills with a green color, the greater the input sound received.
    I checked my permissions for both apps. They seem fine.
    I tried restarting my phone.
    I tried clearing cache on WhatsApp.
    Zoom was a fresh install today.
    I can record a WhatsApp voice message.
    Actually, I can't do that anymore. I recorded a WhatsApp voice message yesterday. After that, it seems like my problems started.
    I can't go to the SMS app and do voice-to-text anymore. When I try talking, it doesn't detect anything.
    I can't go to the voice recorder app and record anything anymore. It doesn't detect anything.
    For WhatsApp, yesterday, the other party couldn't hear me. We tried quitting and starting a new call many times.
    Regular voice calls still seem to work, though.
    05-27-2021 08:19 PM
  2. mustang7757's Avatar
    Hi, what Android version is your Note 4 on?
    05-27-2021 08:37 PM
  3. nuraman00's Avatar
    6.0.1.
    All of these problems seemed to have started yesterday. I made 2 voice messages via WhatsApp.
    A few hours later, when I tried a WhatsApp video call, then I noticed the microphone problem.
    However, I've done several voice calls since then using the mobile network, and those have all worked.
    So far, it seems like with WhatsApp, Zoom, the SMS app voice to text feature, and Voice Recorder, all have problems detecting that the microphone is being used.
    05-27-2021 08:41 PM
  4. mustang7757's Avatar
    6.0.1.
    You double check the mics on the phone any dirt or lint in them ?
    Go to your camera app make a video talking and replay it see if your voice is heard .
    05-27-2021 08:45 PM
  5. nuraman00's Avatar
    The camera app appears to be one more thing that isn't detecting the microphone. I didn't hear my voice after recording the video.
    Is there more than one mic?
    Is there a different mic for voice calls, as compared to the ones WhatsApp, Zoom, SMS, Voice Recorder, or the Camera App would use?
    05-27-2021 08:57 PM
  6. mustang7757's Avatar
    Should be 2 or 3 on this device 2 at bottom and one on top , look like little pin holes
    05-27-2021 09:05 PM
  7. nuraman00's Avatar
    It's possible one other incident messed up my phone.
    I was calling someone Wednesday evening, and at one point, my phone restarted while I was on the call.
    That's never happened to me before.
    Maybe the mic got messed up then.
    05-28-2021 12:31 AM
  8. nuraman00's Avatar
    Ok, now I understand.
    Thanks.
    05-28-2021 12:31 AM
  9. nuraman00's Avatar
    Ok, somewhat good news.
    I was using Phone Doctor Plus, and it was doing its tests, including a mic test.
    https://play.google.com/store/apps/d...hl=en_US&gl=US
    When it got to the mic test, my phone restarted for some reason.
    After it restarted, the SMS voice to text; Voice Recorder; and video recording using the camera app all recorded audio.
    I will try Zoom and WhatsApp tomorrow.
    05-28-2021 12:37 AM
  10. nuraman00's Avatar
    So a question I have, in trying to better understand this, is that when making a normal voice call, does it use a different mic then SMS voice to text, Voice Recorder, WhatsApp, Zoom, and the Camera app?
    05-28-2021 01:01 AM
  11. mustang7757's Avatar
    It has couple different microphone so I'm not sure which ones it uses .
    nuraman00 likes this.
    05-28-2021 11:33 AM
  1. Why is my WhatsApp not allowing right to left
    Last Post: 06-01-2021, 11:36 AM
  2. Replies: 4
    Last Post: 06-01-2021, 11:34 AM
  3. Voice typing will not switch between my selected languages WILL ONLY hear English
    Last Post: 06-01-2021, 11:28 AM
  4. T-mobile 5g not supported
    By Rumblee1 in forum Sony Xperia 1
    Last Post: 05-28-2021, 06:59 PM
  5. LTE not connecting
    Last Post: 05-27-2021, 06:40 PM
