Is the snapdragon 805 in Note 4 64 bit processor or is it just the exynos version
Based on what the responses are, the exynos 5433 is 64 bit? Not only that, even though the exynos has lower clock speeds the benchmarks show that the exynos is in the lead over the snapdragon in a bunch of tests.
I think the problem with the 64 bit Exynos chip used in the non US version is it is not compatible with 4G/LTE which is why we're getting the Snapdragon version. I'm guessing Samsung will not upgrade the US version Note 4 to the 64 bit Snapdragon chip but instead wait for the Note 5 to release it.
Or Maybe they will release Note 4 Prime with 64bit SD810 after couple months. Have you seen S5 and S5 prime ?!
Talk about getting no updates they will say it can't handle the updates since it's not 64 bit.
I'm very disappointed the USA (Snapdragon) version isn't 64 bit with Android L just around the corner. I'm guessing the long lead time vs. the introduction timing is the reason but that doesn't explain the HTC midline model just introduced that does support 64 bit. Very disappointing for Samsung's top of the line phone to not be available with 64 bit in the US.
Android Os will support 64 bit within the next month or 2. And it won't be Google who doesn't support the updates it will be the phone manufacturer. And I'm guessing the big discount Qualcomm gave Samsung played the biggest part.
