12-17-2014 11:51 AM
65 123
tools
  1. anon367353's Avatar
    How come every single site says it's 64 bit I can't even find one that says it's 32 bit and you done nothing to prove it's 32 bit other than say it is? You got anything other than your opinion?
    09-08-2014 05:07 PM
  2. ace0187420's Avatar
    09-08-2014 09:54 PM
  3. Denelor's Avatar
    Future proofingLet’s take a step back, though. At the moment, having a 32-bit processor is no bad thing. There’s currently no intrinsic benefit to having an Android phone with a 64-bit chipset.*
    However, that won’t be the case for that much longer.*
    Android L is going to offer native support for 64-bit processors, and that involves a substantial re-working of the system so it can make use of what those CPUs pack. This isn’t a tweak, it’s groundwork for the future.*
    And we’re not going to see 64-bit chipsets reserved for elite phones either. Qualcomm has already revealed the Snapdragon 610 for mid-range phones, and the Snapdragon 410 for those closer to entry-level.*
    It won’t just be the*Galaxy S6*that’ll be looking down at the Note 4. It’ll be pretty much every new phone.
    So why doesn’t the Galaxy Note 4 have a 64-bit CPU? It’s a case of timing.*
    Samsung does not rely exclusively on its ‘own-brand’ Exynos line for top-tier devices like the Note 4, presumably because it doesn’t have the capacity to roll-out the tens of millions of units required. And while Qualcomm’s low-end and mid-range 64-bit chipsets are due out by the end of the year, the top dog Snapdragon 810 isn’t set to arrive until 2015.*
    In order to arrive this year, the Note 4 had to be sacrificed. And now it has Jack syndrome, doomed to be old before its time (RIP Robin Williams).
    32-bit vs 64-bitOf course, we haven’t yet explained why having a 64-bit processor is going to be important, only that soon just about every new phone will have one.
    So what’s the big deal? The main advancement offered by a 64-bit processor is that it exponentially increases the memory address space of a system. Apologies for using a techy term that seems about as impenetrable as a James Joyce novel with half the words missing (wouldn't that improve it? - Ed.), but it can be explained reasonably simply.*
    Address space refers to the total amount of physical memory that can be accessed by a CPU at once time. In a 32-bit system the total address space is around 4GB.*
    And that's the limit of any memory accessible, not just plain RAM. And that’s why we’ve more-or-less seen mobile phones hit a brick wall at 3GB – a 32-bit system cannot access more than this in one go. While the Snapdragon 805 has a special LPAE system in place that would allow 4GB to be used, the Note 4 is very much in 32-bit RAM territory.
    With a 64-bit system, this address space is raised from 4GB to theoretical maximum that ranges in exabytes (a billion gigabytes). There is no real ceiling with 64-bit.*
    64-bit processors also feature many more registers, which allows for much greater simultaneous crunching of data. Many might argue this is actually more important than the address space issue.*
    It’s this that is going to put an end to the trend of simply upping clock speeds in CPUs –*changes that have fairly little tangible benefit, and the reason why Android CPUs have barely progressed in the last year or so. CPU registers are where the actual data being worked on by the processor is stored, and more of them will allow a CPU to tackle more data simultaneously.*
    Benchmarks of the Exynos 5433, the processor used in the 64-bit version of the Galaxy Note 4, comfortably outperforms the Snapdragon 805 one already. And that’s without any real 64-bit optimisation in the Android system.*
    How about giving credit where it's due? You ripped that giant wall of text from someone else's article. In fact, it looks like most of your posts in this thread a ripped from that article. Unless you're Andrew Williams (the article's author), that's a ****ty thing to do.
    Why being non-64-bit kills the Galaxy Note 4's futureproofing - Opinion - Trusted Reviews
    Not cool.
    09-09-2014 10:52 AM
  4. clevin's Avatar
    lets be realistic here, how long was 64bit CPU in existence? 64 bit OS?
    and guess what, every single software out there has a 32bit version, and 99.9999% only have 32bit version.
    This 64bit mania on mobile phone is all fake, at least for next 5 years.
    09-09-2014 11:32 AM
  5. Denelor's Avatar
    I think it might be faster than 5 years. Mobile phone development has paralleled desktop computer development just at a much higher rate of change. I see 2 years maybe or 3 years likely, but that's just a subjective number I get from watching the industry. The first 64-bit OS (of Android) is NOT going to be the one that makes 64-bit phones dominant. It's just not. Whatever Android-M is will probably be the one. L is the 32-to-64 bit transition OS.
    But even allowing for a much faster rate of change Qualcomm's 64-bit chips aren't even shipping until the end of this year and (more likely) next year with the next round of flagship phone due out in what? May 2015? Given that you can't convince me that 64-bit is going to be the standard by the end of next year. Will it be used by some apps or features? Sure. But it's not going to break the functionality, or even marginally impair the functionality of today's high end 32-bit phone.
    09-09-2014 11:45 AM
  6. ace0187420's Avatar
    To begin with I never said I wrote just posted available information. I also wasn't sure if you were allowed to post links to other pages which is against some forums rules. What wall of text?
    09-09-2014 08:26 PM
  7. Denelor's Avatar
    You don't have to reply with a link to attribute the original author. I'm pretty sure if someone posts something without saying someone else wrote it, the natural assumption is that the poster wrote it.
    09-09-2014 09:52 PM
  8. l3uddz's Avatar
    Both Qualcomm and exynos are 32-bit. Exynos 5433 is wrongly mentioned in various forums as 64-bit, couldn't be more wrong.
    And another point being mentioned that Exynos not compatible with LTE. This is plain wrong, and misinformation. For example, Note 2 used Exynos 4412 with LTE. Exynos 5430 also has LTE-A with Intel's XMM 7260 modem.
    Just a follow up, was reading xda forum and one of the guys said something interesting..
    Instruction set ARMv7 is in ARM Cortex A53 and ARM Cortex A57. I have been play with HTC Desire 510 64bit for a while in shop. Installed Antutu and it show ARMv7 in details.
    ARMv7 is read from OS as Android 4.4 is 32bit.
    IF Exynos 5433 is 64 bit, we will have more with Android L
    So if we lucky the exnyos could be 64bit
    09-10-2014 02:49 AM
  9. anon367353's Avatar
    First of all apologies to "ace0187420", he was right about the 64-bit part. I did some new digging, and found conclusive evidence that it's a 64-bit A57-based SOC.
    This is Exynos 5433 Geekbench result : http://browser.primatelabs.com/geekbench3/745794
    Concentrate on variant 1 part 3335 revision 0
    variant 1 revision 0 = r1p0.
    part 3335 means it's part of A57 family. Check the proof below.
    0xD07 is equivalent to 3335 in decimal, which is the number mentioned in Geekbench.
    Also check it says "AArch32". This is another proof that it is A57-based. AArch32 is ARMv8 32-bit execution state and is meant for 64-bit SOC.
    Why the hell Samsung named it Exynos 5xxx is beyond my imagination.
    Note: We can also see new Exynos 7-series processor in works which also based on A57. No idea what happened to Exynos 6-series.
    Few details here: https://www.mail-archive.com/linux-s.../msg35957.html
    ace0187420 likes this.
    09-11-2014 09:19 AM
  10. ace0187420's Avatar
    It's cool just confused as why they would make one version with a 64 bit processor and the other 32 bit while knowing the next os update will be 64 bit.
    09-12-2014 08:58 PM
  11. Yoink676's Avatar
    http://browser.primatelabs.com/geekb...aseline=775311
    Well here's a geek bench comparison of exynos 5433 variant with s805 variant.
    09-13-2014 06:45 AM
  12. ace0187420's Avatar
    The exynos is clearly much better so paying the same price for a phone that isn't quite as good doesn't make a lot so sense should of made the phones the same. Then at least people wouldn't feel like they were getting a a lesser product.
    09-13-2014 08:00 AM
  13. Yathani's Avatar
    I want know if i should get the Snapdargon version or wait couple more days for the exynos
    10-13-2014 06:11 AM
  14. One Love1's Avatar
    Depends, if you are getting it for the VR get the Snapdragon, the GPU there outperforms the exynos almost twice. If thats not your goal wait for Exynos.
    Sadly in Europe we dont have the Snapdragon and i wanted that one.
    12-17-2014 09:48 AM
  15. etdoner's Avatar
    Well the thing is Samsung never announced that they will be unlocking the 64 bit architecture in the exynos version with android 5.0. Though I want it so much since I am rocking one.
    12-17-2014 11:51 AM
65 123
  1. What is the best way to back up your smartphone?
    By Oluwadare Oyadiji in forum Android Apps
    Last Post: 09-19-2014, 04:27 PM
  2. Samsung Galaxy Note 4 Impressions! (Specs & features)
    By TechTube14 in forum Samsung Galaxy Note 4
    Last Post: 09-05-2014, 01:54 PM
  3. Replies: 2
    Last Post: 09-04-2014, 06:16 PM
  4. Note 4 wallpaper HERE!
    By Yathani in forum Samsung Galaxy Note 3
    Last Post: 09-04-2014, 04:56 PM
  5. The red light stopped coming on when charging my Galaxy s3
    Last Post: 09-04-2014, 03:29 PM
