Aside from the price difference, the only differences I see between the standard Note 4 and the Note 4 Edge are: (from Galaxy Note 4 vs. Note Edge: 5 Things Buyers Need to Know )
1. Edge is smaller (5.6 inch vs 5.7 inch)
2. Edge has smaller battery (3000 mah vs 3200 mah)
3. Edge has a (somewhat) cool curved edge
I suspect the last option will make it difficult (if not impossible) to put a "screen saver" on the phone - especially a glass one.
Can anyone suggest why you'd want to get the Edge over the standard Note 4??
