Note 4 Is no ip67 a deal breaker?
67srbell
321
I'm coming from the S5. Yes, I get it that ip67 isn't necessary, but it is pretty cool to know that it is there just in case (rain, shower, pool, etc).
Anyone else on the fence w the N4 because it lacks ip67?
Star-Lord
186
Re: Is no ip67 a deal breaker?
No. I'm pretty sure a mild splash of water won't affect the Note 4. The ip7 is a gimmick like 4K video is.
jspring86
120
I actually prefer that it isn't, the little flap on my S5 is annoying as hell, glad it won't be on my Note 4. Yes, I know I can remove the flap from the S5, but I'd rather it not be there in the first place.
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
Doesn't bother me. I have no problem with keeping my phone away from water.
Connert
1,071
16
38
Not a deal breaker for me, but I am a little disappointed. I was hoping we would have it.
bembol
Trusted Member
Jun 18, 2011
3,093
106
63
I loved it when I had the S5 but when I upgraded to the G3, I don't miss it like I thought I would.
I guess it didn't help that the flap cover was poorly designed.
tapatalk LG pro D852
codyoehl
562
Yeah I really the GS5 being water resistant
It's really just for peace of mind knowing that if I spill a glass of water on the phone or it gets rained on, it won't destroy the phone
I personally think this should be standard on phone
And the charging port cover isn't a big deal, I mean you take it off maybe once a day (or at night) and put it on in the morning
If that two seconds of work is too much for you, then I don't even know.
Posted via Android Central App with my Samsung Galaxy S5
67srbell
321
So, no N4 for you then?
Star-Lord
186
It isn't a gimmick ...
Sent from my SM-N900T using Tapatalk
If it walks, talks, and quacks like a duck then it's a duck.
Your post is a Gimmick
Your well thought out response has floored me.
It's actually IP67. IP ratings for dust and water have 2 numbers after them.
Waterproof Phones: IP ratings explained - Opinion - Trusted Reviews
Sent from my SM-N900V using Tapatalk
Understood, I keep getting it mixed up.
Closingracer
Banned
Apr 5, 2012
3,033
It isn't a duck though ip67 is certified to be dust proof and water resistant. It's like me calling the s pen a gimmick
worwig
990
50
Deal breaker, no. Disappointing, yes.
I use my devices attached to a clamp on my motorcycle as a GPS. A waterproof phone would be much better than the sandwich bag that I now use.
The S5 IS a deal breaker, with only 16gb of internal storage. (My stuff won't install to extSD)
But I also understand that a waterproof phone is sealed and might run hot, and you lose space for other features. Plus you have that flap thing.
For now, I'll do without.
So is the S5 16gb because of the space lost to water seals?
beh
1,378
16
An IP67 rated device would not be much use if exposed to rain while mounted on a motorcycle going at highway or even residental street speeds if I understand the IP67 rating for water resistance.
Willn
90
All this waterproof stuff with electrical devices really worries me. Lithium batteries need to vent or they sometimes explode. If the device heats up and is air/water tight then the heat is trapped inside the device for prolonged periods of time. If the device not water tight then the heat can escape as needed.
I don't think water proof phones are a gimmick as it serves a purpose to fill a demand of the market. Some people need this. But with that said I would imagine most people don't need waterproof phones. It has its purpose but doesn't belong on a powerhouse/big battery phone like the note 4 which was designed for business purposes. It's suited for a more casual phone like the S5.
samyblaze
