09-18-2016 10:21 PM
71 123
tools
  1. clatus's Avatar
    Who cares about more invisible free between carriers in the states.... Yes you could use a Verizon note 4 on t-mobile but no LTE.
    Sent from my SM-N900T using Tapatalk
    It's not just the states. Verizon is sim unlocked for any country.
    Yes you can use LTE - you just have to change your apn settings, etc.
    You can't use HSPA+ though - just HSPA.
    10-06-2014 12:40 PM
  2. Closingracer's Avatar
    No you can't... Not the same bands
    10-06-2014 12:49 PM
  3. dpham00's Avatar
    Depends on the phone. The Verizon 5/5s/5c/6/6+ gets a number of international lte bands and the 5s/5c/6/6+ gets all usa lte bands used by att and tmobile. My note 3 can get 4glte on tmobile and att, though the latter is very limited.
    Sent from my Verizon Samsung Galaxy Note 3
    10-06-2014 01:12 PM
  4. Closingracer's Avatar
    But this isn't about the iPhone nor the right place about it so thus I could care less about iPhones. Generally phones bands is dependent on the carrier you buy it from
    10-06-2014 01:13 PM
  5. clatus's Avatar
    Yes you can! They both use band 4, 1700 mhz.
    10-06-2014 01:38 PM
  6. Closingracer's Avatar
    OMG 1 band..... Out of what? And only for T-Mobile
    I rather go to sprint then ever touch Verizon unless I have to get Verizon for whatever reason.
    10-06-2014 01:50 PM
  7. Jdroid3's Avatar
    +1
    10-06-2014 01:51 PM
  8. clatus's Avatar
    That's the only band that matters right now! AT&T uses band 4 1700 mhz too!
    700 mhz will change things in the future though!
    Why would you rather use sprint when Verizon has the most reliable network in the country? I still have unlimited data though so I'm a little biased.
    10-06-2014 01:58 PM
  9. Closingracer's Avatar
    That's the only band that matters right now! 700 mhz will change things in the future though!
    Why would you rather use sprint when Verizon has the best reliable network in the country? I still have unlimited data though so I'm a little biased.
    I don't like Verizon and how they operate in general..... I have friends with Verizon and I had AT&T and speed and connection is about the same if not a bit better with AT&T for me in nyc.
    Verizon doesn't operate in the band 12 block A of the 700 mhz which is what they sold to t-mobile?
    10-06-2014 02:01 PM
  10. clatus's Avatar
    Yea the 700 mhz were sold on a different band but T-mobile hasn't built anything on it yet. Right now they only use band 4.
    10-06-2014 02:31 PM
  11. Closingracer's Avatar
    Yea the 700 mhz were sold on a different band but T-mobile hasn't built anything yet. Right now they only use band 4.
    Verizon 700 mhz is different then t-mobile and aren't compatible. The note 4 does have T-Mobile 700 mhz frequency band 12 in the radio
    10-06-2014 02:34 PM
  12. dpham00's Avatar
    Yes it does for the tmobile and att version
    Sent from my LG G Pad 8.3
    10-06-2014 02:41 PM
  13. clatus's Avatar
    T-mobile 1700 mhz is already built in the major cities and is compatible with Verizon. 700 mhz hasn't even been built yet. So it will still be compatible where it is now.
    Forecasting years out for compatibility doesn't matter because you will upgrade your phone anyway and can always change carriers down the line.
    Right here and right now, Verizon phones are fully compatible on T-mobile LTE
    10-06-2014 02:44 PM
  14. Closingracer's Avatar
    Can you provide the link where you saw that?
    Read that somewhere here I think or somewhere where it does have T-Mobile new 700 mhz frequency and right band included in the phone
    10-06-2014 02:44 PM
  15. Closingracer's Avatar
    T-mobile 1700 mhz is already built in the major cities and is compatible with Verizon. 700 mhz is just starting to roll out.
    T-mobile 700 frequency is not compatible with Verizon..
    10-06-2014 02:45 PM
  16. dpham00's Avatar
    Ok the tmobile version does have b12 support. But not Verizon
    10-06-2014 02:46 PM
  17. clatus's Avatar
    700 mhz were unused. That means T-mobile LTE cities are all band 4 1700mhz which means Verizon is fully compatible with T-mobile LTE.
    Years down the road that might change, but that doesn't matter because you can always change carriers and upgrade phones down the line if you really need that compatibility between US carriers.
    Right now, Verizon is the most compatible carrier.
    10-06-2014 02:52 PM
  18. dpham00's Avatar
    Speaking generally though, iPhones account for over half of the smartphones sold by Verizon, so it is fair to discuss it generally. Now if you are talking specifically about Android then I would agree with you.
    10-06-2014 02:59 PM
  19. Closingracer's Avatar
    This is called android central for a reason
    10-06-2014 03:28 PM
  20. Wonder77's Avatar
    What do you use the S Pen for?
    I use it a lot for my art.
    09-18-2016 10:15 PM
  21. Wonder77's Avatar
    AT&T. open GSM global standard network allowing BYOD and SIM freedom vs. closed CDMA network requiring proprietary phones.
    What does this mean? I just ordered the verison note 4 (unlocked) but I had a different one before and loved it. What am I loosing by getting the verison version? Also mentioned was the loss of the s pen planner? I use that alot.
    09-18-2016 10:21 PM
71 123
  1. NOTE 3 battery problem.
    By I_Have_a_Bassbort in forum Samsung Galaxy Note 3
    Last Post: 05-22-2017, 12:48 AM
  2. Why can't I send or receive photos on my Galaxy S4 mini?
    Last Post: 11-30-2014, 06:49 PM
  3. black vs white Note 4
    By goin_nil in forum Samsung Galaxy Note 4
    Last Post: 10-13-2014, 11:42 AM
  4. Replies: 1
    Last Post: 10-04-2014, 07:02 PM
  5. My LG wont let me use launchers or drop down menu?
    Last Post: 10-04-2014, 04:25 PM
