1. browetally's Avatar
    I currently have a Note 3 but just pre-ordered the Note 4 from AT&T. I'm interested in adding the wireless charging feature as I've never had it. On my Note 3 I use the Incipio DualPeo case. Can you use this type of case and have the wireless charger back cover?
    10-05-2014 01:49 PM
  2. rvhs03's Avatar
    A lot of cases are too thick for the wireless charging cover to work. I've researched this a lot, and from what I understand, the spigen cases usually work well with the wireless charging. Hope this helps.
    10-05-2014 01:54 PM
  3. ChemMan's Avatar
    I have wireless charging on my Note 2 and it is simply a coil that slips under the back cover. It makes the phone just slightly thicker and the back cover is a bit rounded. With the cover on it is not noticeable.
    10-05-2014 03:34 PM
  4. Gator352's Avatar
    Amazon.com: Universal QI Wireless Charging Receiver film for micro-USB of All Android Mobile (middle/narrow-interface Up): Cell Phones & Accessories
    This either slips under the back cover or between back cover and case. Works like a charm! I use it on my G3, Note 3, HTC E8, and M7. All mine are placed between back cover and case and are not noticeable at all!
    10-05-2014 06:32 PM
  5. dragonsamus's Avatar
    You'll need either the wireless charging receiver or the official wireless charging back cover. I had the receiver in my Note 3 but noticed sometimes the phone wouldn't charge unless I had the phone perfectly on the pad. Now I'm using the Samsung wireless charging back. I noticed I didn't have to put the phone on the charger exactly for it to start charging. Downside is most cases do not fit with the Samsung cover since its thicker.
    10-06-2014 12:56 AM
  6. bertsirkin's Avatar
    I also use the universal QI wireless charger that Gator352 mentioned above on both a Note 3 and S3. It works great and the coil is very thin, so it should fit inside any back.
    10-06-2014 01:25 AM
  7. sqa4life's Avatar
    Heard a lot about wireless charging. What are "all" the required accessories for the note 3 or 4 wireless charging?
    10-06-2014 01:34 AM
  8. ilordvader's Avatar
    I used to get the Fat battery to last longer
    but once I tried wireless wooohoooo it rocks
    I carry a extra battery that last me full day
    I also have the Extra battery kit
    wish Samsung doesn't delay the wireless cover for 1 month like always
    that sucks a lot
    the good part is I can use all different back covers
    witht the thick battery we could not lol
    I have S5 now... waiting for the Edge
    10-06-2014 03:23 AM
  1. Charging port cover won't stay closed.
    By Bob31464 in forum Samsung Galaxy S5
    Last Post: 02-23-2016, 11:00 AM
  2. Replies: 2
    Last Post: 10-11-2014, 12:15 AM
  3. Replies: 1
    Last Post: 10-10-2014, 08:32 PM
  4. How can I restore my Weather and S Planner apps?
    Last Post: 10-10-2014, 04:46 PM
