I did a bit of looking last night, but didn't find anything. Do you guys know if Samsung will be offering perks? If so, what are they or where can I find them? TIA
Posted via Galaxy Note 3
Check out samsung mobile it has them listed
It's probably the same stuff as the Note 3. Mostly useless lol
The 50 GB for Dropbox is nice -- They will probably offer the 50% off an accessory from their store when you register the device. This is common of Samsung.
The drop box offer is only for new users.
50gb is new registered devices. I know someone which got the offer on note 3 for 2 years then on S5 to etc
Found a code online and just used it to buy the wife an extra battery for her new s5 for 50 percent off. Plan on buying the note 4 an extra battery with the external charger.
Code is: r1H01X01 good for accessory under $50
