1. MannyZ28's Avatar
    I am currently using a cheap leather side case from Amazon, and when I say cheap, the thing cost 3 bucks. It's looking a bit used by now but I am having a difficult time finding a quality replacement for it. I saw a couple on shop android, but for whatever reason, the flap that is supposed to cover the phone doesn't extend over the whole length of the case exposing the phone to dust and rain. Other side cases literally just have a strap on top to hold the phone in place.
    I don't want one of those wallet type cases that the phone is attached to, just a leather case that straps to your belt into which you drop the phone and completely covers it with a flap.
    Thanks for any suggestions.
    10-12-2014 09:55 AM
  2. Honey_184's Avatar
    Check out ebay, this one might fit your needs but I would contact the seller to make sure the Note 4 would fit inside. http://m.ebay.com/itm/331322630635?nav=SEARCH
    MannyZ28 likes this.
    10-12-2014 10:41 AM
  3. AnnDroid's Avatar
    That's a gorgeous case.
    10-12-2014 04:16 PM
  1. Another note 4 manuel
    By Kingb1186 in forum Samsung Galaxy Note 4
    Last Post: 10-13-2014, 12:11 AM
  2. Which is best case for Nexus 5
    Last Post: 10-12-2014, 10:35 PM
  3. Can't get a Pro View case off my S5
    By John Ball1 in forum Samsung Galaxy S5
    Last Post: 10-12-2014, 07:19 PM
  4. Note 4 (AT&T) owner's manual available online
    By Maynard in forum Samsung Galaxy Note 4
    Last Post: 10-12-2014, 07:01 PM
