Yup. With a screen like this the screen will take a huge amount of battery. That's why I always like black set ups.
Very nice theme there. If you want to go into details it would be cool.
Thanks.
First off... I use Nova Launcher prime.
Then I set up each home screen to use a different wallpaper using Multi Live Wallpaper in the play store. The non light bulb pages are just black. The light bulb wallpaper is attached.
For the weekday weather forecast I used eye in the Sky widget from play store. For the big today forecast and city I used a UCCW widget and a skin created by a guy who created another theme.
For the other homescreen I used Simple Calendar widget. Underneath that I used a dark themed Any.do Widget.
If you or anyone else needs more details or anything just pm me or whatever. I'd be glad to help.
