Note 4 Screenshots! Show use those awesome home screens & more!
mchi5
993
What widgets are you all using in your home screens?
I began using the weather and clock widget from the play store and looks really nice.
Trying to figure out what else would be good.
Sent from my new Note 4 via Tapatalk
mchi5
993
Keeping it simple right now. Trying out different weather widgets.
brynnadise
Active member
Oct 14, 2014
26
Mine is also pretty simple right now, though I do like a clean look. The shot w a photo of my dog is the main page, the calendar is a swipe to the left and the car widget is a swipe to the right.
None of my calendar events transferred. Definitely in the market for a nice looking widget that I can arrange the same way I have in the screenshot, but that syncs with Google so I don't have this problem again :/ It will take forever to enter everything in again manually.
brynnadise
Active member
Oct 14, 2014
26
How do you change the look of the folders? my folders are hideous!
Tap and hold the folder until the little menu comes up. Select 'edit' and tap the icon photo. You will then be prompted to choose a source for the photo or icon you want to replace the folder icon with :) I hope that helps!
tlo07
455
10
What icons are those?
hubtime
13
That would be HD Widgets. Download from the Play Store. Long Press on Home Screen, choose HD Widgets, choose 4x1, Top left of screen should have a menu, choose "Glass Gems" (or you may have to download the theme - its free) scroll to the right until you see the weather forecast. You will then have the option for "No background" which allows your wallpaper to be seen... almost transparent
jokomad
