Is that a glass screen protector?
I like "earth and moon". It uses gyroscope for 3d effects.
I will have to look at the packaging when I get home, it was what the Best Buy guy had on his personal note 4 when i went in to get mine, he took his knife and tried to scratch his own screen....i was sold...Lol...it is mirrored
Zagg mirrored glass. Does it affect the brightness of the screen at all? I wanted it but was worried.
Any air bubbles or halo around the edges?I have not noticed it, but then again it was installed at best buy so I don't know anything other than with it on the screen. I do have to wipe it down occasionally because of finger prints but thats true w/out a protector on the screen. LOL
Norwich? Which state?
Note 2 via Android Central App
I'm in the UK bud.
No air bubbles at all......Halo? I guess Im not sure what you mean by that........
It doesn't go completely to the edge but it does not bother me. It is a zagg invisible shield mirror glass protector.I have the glass from Bodyguardz. It's nice, but doesn't go to the edges. The Note 4's screen is actually curved on the edges, if you haven't noticed.
The BodyGuardz is flat, so there's a Itty bitty space near the edges where it doesn't quite touch the glass, leaving a slight halo effect.
Tap and hold the folder until the little menu comes up. Select 'edit' and tap the icon photo. You will then be prompted to choose a source for the photo or icon you want to replace the folder icon with I hope that helps!
No, I am not rooted. If you tap and hold, does a menu pop up? There should be an 'edit' option at the top of the menu. Once you click that, you will see a picture of the icon you selected as well as some wording. Click the actual picture and you should be able to change it to whatever you want.I don't see this option. Are you using some sort of mod or root process?
