What weather widget is that??Getting into the holiday mood!
How can I get that weather instead of the one I have.?
Sidebars made using Nova prime and zooper widgets
It's a trick using the "Wipe" effect and the layered widgets. Basically(for mine) I used a zooper template and layered the app icons over it, and the clock under it. The grid is 8x16.Could you direct me to the specific settings in Nova Prime where I might find the sidebar options?
I love this! Is it a specific theme?Changed it up since my first post.
Here's my home screen....hope the picture came out ok....I'm not used to my note 4 yet!!
Is this a daily bible verse widget?
