al3azim
Thanks. Is this completely custom or did you take a existing widget and build of off it? Just want to know how much work is needed to set this up before I purchase zooper pro.
The Zooper widget I created is custom, built in from scratch but it is extremely simple and took less than 10 minutes to complete.
The weather widget is a separate widget, called xwidget and the theme is an existing theme with some modification by me to fit my needs.
Zooper widget is very simple to use and offers a lot of customization options. Highly recommended.
