Can you tell me the settings ? I'll use other icons.
Sent from my Frost White T-Mobile Galaxy Note 4
Desktop Settings (You might need to change some of this depending on the phone you have)
Desktop Grid: Rows - 7 Columns - 4
Width Margin: Large (You might prefer Medium)
Height Margin: Small
Scroll Effect: None
Wallpaper Scrolling: Off
Infinite Scroll: Uncheck
Label Icons: Check
Dock Settings
Dock Style: On - Transparency 44% - Color #e2e1e1 - Rectangle
Dock Icons: 4
Width Margin: Large (Make this the same as your desktop width margin)
Dock Height: Large
Label Icons: Check
Label Shadows: Uncheck
Dock as Overlay: Check
Look and Feel
Colour Theme: #ffffff
Icon Size: 105% or 110% (You might need to change some of this depending on the phone you have)
Icon Font: Normal
Screen Orientation: Default
Scroll Speed: Nova
Animation Speed: Faster than light
App animation: Zoom
Show notification Bar: Check
Transparent Notification Bar: Check
And that is basically it, I hope you get it looking right! Also, if you have a smaller screen than the Note 4, look up iOS 8 on an iPhone 6/5/4s/4 and adjust some settings to make it look similar.
