Note 4 Screenshots! Show use those awesome home screens & more!
lpt2569
1,355
91
48
Unless I'm missing something, long pressing the icon only gives me the option to move it, remove it or create a foler
Yep, my bad. If you are using a third party launcher, they usually give you the option to edit them with a long press (nova works like this, and I think others as well, but not all of them), but stock TW definitely does not. Are you stock or using a launcher?
barrettdaniel
105
I was using TW. I tried using Nova yesterday and it worked. Not sure if I want to keep using Nova now or stick with TW lol
hamsterwheel
372
Re: Note 4 Screenshots! Show use those awesome home screens & more!
Would you mind sharing the wallpaper and set up for the third screen with the mountains? Looks really nice!
Sure..
The icons are Spark UI by Goktug Ulas in playstore
The bottom widget is by Josh Heckert on g+
Weather set is by Kelly Kretchek also on g+ ( I made the top zooper)
I will post the wall in a bit...
anon(8702321)
297
My two homescreens that I constantly switch, and their wallpapers!
Laila Nance
