lpt2569
Unless I'm missing something, long pressing the icon only gives me the option to move it, remove it or create a foler
Yep, my bad. If you are using a third party launcher, they usually give you the option to edit them with a long press (nova works like this, and I think others as well, but not all of them), but stock TW definitely does not. Are you stock or using a launcher?
