01-04-2015 01:53 AM
58 123
tools
  1. Mr-Guy's Avatar
    I had a problem using it with skiplock, but knowing that wasn't going to be working with lollipop I killed it and now the scanner works perfectly. Love it.
    kevinpleasants likes this.
    01-03-2015 11:09 AM
  2. KreepyKen's Avatar
    I've found that unlocking the phone while driving is FAR easier and requires less attention using fingerprints than it is using a pattern or pin.
    01-03-2015 12:05 PM
  3. felloffthetruck's Avatar
    Turned it off, a huge pain in the @ss.
    01-03-2015 12:54 PM
  4. ChemMan's Avatar
    I try not to use my phone at all when driving, it is to much of a distraction.
    It is amazing how many complain about the scanner, this thing is so simple it is absurd. Iphone's fingerprint scanner, if it is much easier it is probably much less secure.
    01-03-2015 03:46 PM
  5. NeilWhitear's Avatar
    Having used both finger print sensors on the iPhone 5s and Note 4, both of them work well.
    The main differences are;
    1. iPhone 5s allows you to unlock with your finger at any angle as it does not require a movement.
    2. With the Note 4 you have to move your finger down over the sensor keeping your finger level.
    Of the two I personally feel the iPhone's finger print sensor is better but no enough to give up my amazing Note 4.
    01-03-2015 03:51 PM
  6. ChemMan's Avatar
    iPhone encryption stops FBI, but not this 7-year-old - Dec. 1, 2014
    Note 4 is a bit more secure than the iphone I think.
    01-03-2015 04:41 PM
  7. cowincanada's Avatar
    some comments are just idiotic
    01-03-2015 09:25 PM
  8. harryhoudini66's Avatar
    Not sure you are aware of the forum rules. Play nice cowincanada.
    01-04-2015 01:53 AM
58 123
  1. Why is my Samsung Galaxy Note 10.1's screen black?
    By Sadistic_heroine in forum General Help and How To
    Last Post: 10-14-2014, 09:40 AM
  2. Replies: 4
  3. Replies: 1
    Last Post: 10-14-2014, 08:49 AM
  4. is the new motorola droid turbo going to have amoled display?
    Last Post: 10-14-2014, 08:47 AM
  5. Replies: 0
    Last Post: 10-14-2014, 08:24 AM
