11-16-2014 05:09 PM
307 ... 56789 ...
tools
  1. browetally's Avatar
    Lovely...back-ordered for 4 weeks.
    10-16-2014 04:23 PM
  2. muadib279's Avatar
    Yeah, sadly I saw this thread too late...
    10-16-2014 04:32 PM
  3. monsieurms's Avatar
    Nice! Yeah Samsung said you have to buy the cable separate (they want more money sadly ).
    I haven't used Samsung's before. What do you need a cord for? The travel chargers I've used in the past have their own plug for the wall. No cord required. Most allow you to charge a device and a battery at the same time by putting in a standard USB to MICRO usb cord that you already have (included with phone). Am I missing something?
    10-17-2014 07:47 AM
  4. monsieurms's Avatar
    Yeah I saw that. Not going to post my choice, going to wait until I get them, try them out, then if they work, I will post up what I got and where. I know it is possible that I might just "crash and burn" with these..
    On my S4 I had (2) Anker batteries and 1 OEM Samsung that I rotated so they got roughly even usage. If anything, the OEM battery was more heavily used because I didn't have the Anker backups for the first couple weeks I owned the phone.
    The Anker batteries were perfect early on, but despite being used exactly the same way, 15 months later, the Sammy battery still functions very well, but both Anker batteries drain quickly and in particular no longer hold charges very long when out of the phone. 2-3 weeks in the closet doesn't bother the Sammy much. But it drains the Ankers almost to 0. The Sammy battery shows some wear. The Anker batteries are pretty much useless. I'd have to say, as a result, that I'm a lot less happy now with Anker than I was once upon a time.
    10-17-2014 07:51 AM
  5. ilordvader's Avatar
    10-17-2014 09:02 AM
  6. trucksmoveamerica#AC's Avatar
    Bonus for you late nighters...Samsung website has the spare battery kit in stock again. I just competed my order and got the 50% off to. Better hurry.
    https://forums.androidcentral.com/e?...token=JcozBjW7
    I should have it here and fully charged when i get my Verizon note 4. :-)
    Sent from my SM-N900V using Tapatalk
    monsieurms likes this.
    10-18-2014 12:10 AM
  7. Almeuit's Avatar
    Yeah it has to plug in via a cord. It doesn't plug into the wall.
    10-18-2014 12:14 AM
  8. browetally's Avatar
    Galaxy Note ® 4 Extra Battery Kit
    And boom goes the dynamite! Thanks for the heads up just completed my order.
    10-18-2014 12:17 AM
  9. Chuondroid's Avatar
    What is the code for 50% off? TEll me asap!
    10-18-2014 12:25 AM
  10. ilordvader's Avatar
    This would be worth buying if
    it had a light indicator on how much its charged like 4 led lights than just 1
    or if it did the Fast charge like the phone 50% in 30min
    10-18-2014 12:29 AM
  11. Chuondroid's Avatar
    Do you know what code currently works? I'd like to purchase this ... like right now, but none of the codes mentioned previously works...
    10-18-2014 12:32 AM
  12. Chuondroid's Avatar
    Dude, $20. Nuff said
    10-18-2014 12:33 AM
  13. screwhead728's Avatar
    I NEED THE CODE PLEASE! I tried using the codes mentioned on this forum and nothing!
    10-18-2014 12:36 AM
  14. Bimmerz's Avatar
    This is the one I just used (got from XDA) r05Q1a40, and it worked. Dumb-*** me bought an extra battery too, now I'll have 3! I forgot the kit already came with a spare battery! Ugh! Oh well, I can probably sell it after I get it, since Samsung won't let me change my order. =)
    10-18-2014 12:49 AM
  15. hopefulfarm's Avatar
    I bought an extra battery too. Worth it for am oem at 50% off.
    r3887W2 worked for me.
    Rocking the Note 4
    10-18-2014 12:51 AM
  16. Ntchwaidumela's Avatar
    Once you register your device with Samsung, they email you a discount code for the 50% off any item of $50 or less. Right now, the Extra Battery Kit is back-ordered. However, if you place the order anyway, they'll email notification when they're available so you can complete your order.
    10-18-2014 12:59 AM
  17. Chuondroid's Avatar
    Thanks Bimmerz! Code worked now I got my order in
    10-18-2014 12:59 AM
  18. reesh11's Avatar
    Is it bad that I wore down the original and the spare and now I'm back on the original? Lol I've been on this thing all day!
    Chuondroid likes this.
    10-18-2014 01:03 AM
  19. screwhead728's Avatar
    Thanks Bimmerz! Appreciate. Just placed my order.
    10-18-2014 01:04 AM
  20. Ntchwaidumela's Avatar
    Samsung has the extra battery charging kit for $40,there is a 50% coupon from the other thread bringing it down to $20. Comes with battery and charger.
    Note 4 What case you going for? - Page 9 - Android Forums at AndroidCentral.com
    Sent from my Verizon Samsung Galaxy Note 3
    When you register your device with Samsung, they email you a discount code for 50% off on any item under $50. The Kit is back-ordered right now. But if you place the order, they will email you when it's available and you can complete your order using the discount code.
    10-18-2014 01:08 AM
  21. fatboypup's Avatar
    Thanks got my order in
    10-18-2014 01:10 AM
  22. bembol's Avatar
    No but thanks for the heads up.
    I couldn't find an LG Extra Battery Kits so I bought the Powerocks 6000mAh battery pack instead, no need to carry microUSB cables either since it's built-in.
    10-18-2014 01:20 AM
  23. Ntchwaidumela's Avatar
    Just received email notification that the Kit is now available. If you ordered while it was back-ordered (like me), you have to place a new order. You can use your discount coupon at checkout. Just re-ordered and everything was smooth going. Should have it in about 3 days.
    10-18-2014 01:39 AM
  24. skeetre's Avatar
    I just ordered mine a few mins ago. Didn't even see this thread until after the fact. I used code r96N5x6 and it didn't mention being out of stock or back ordered. Just emailed me my order confirmation. I thought cell phone batteries were like $60-$80 still. Didn't realize they were so cheap... and then 50% off $30 or $40 for the whole kit, amazing!
    Ntchwaidumela likes this.
    10-18-2014 01:41 AM
  25. Ntchwaidumela's Avatar
    Has anyone seen the prices they're asking on eBay? SINFUL!
    10-18-2014 01:42 AM
307 ... 56789 ...
  1. Will all Note 4 Tempered Glass Screen Protectors have this "Halo" effect?
    By felloffthetruck in forum Samsung Galaxy Note 4
    Last Post: 12-10-2015, 02:29 PM
  2. Why is my Galaxy S Plus shutting down when surfing the internet on 3g?
    By Ron-diesel in forum General Help and How To
    Last Post: 10-16-2014, 08:23 PM
  3. Why isn't my Samsung Galaxy S5 not playing all my MP3's?
    Last Post: 10-14-2014, 09:44 PM
  4. Why can't I close the windows on my Samsung Galaxy S4 Active?
    Last Post: 10-14-2014, 02:56 PM
  5. Serious battery problem with GALAXY TAB S
    By LightningFast in forum Ask a Question
    Last Post: 10-14-2014, 01:06 PM
