12-15-2015 12:35 PM
147 ... 3456
tools
  1. rjlesperance92's Avatar
    I can't seem to get the bt on my n4 to discover my 2011 elantra. It worked with my moto bionic for BT calls, never messed with trying to play music.
    11-16-2014 11:34 PM
  2. kobe008's Avatar
    I have a JVC Hdx80bt or something like that and it works fine. Getting a 2015 Rogue this week and I'm guessing it will work fine.
    11-17-2014 01:23 PM
  3. AndroidAmberina's Avatar
    I'm having problems pairing my Note 4 to my 2014 Subaru Forester. My Note 3 worked just fine, then I decided to try the S5. It was a PAIN to pair (had to go through the controls on the steering wheel only, not on the radio). It worked like a champ once I FINALLY got it paired that way. Then I decided I missed the bigger screen and went to the Note 4. Now It won't pair at all. I should learn to leave well enough alone I guess!
    12-24-2014 03:37 PM
  4. LaTuFu's Avatar
    Check with your dealership or search forums for your vehicle. Verify that the head unit in your vehicle has the most current firmware installed. Verify that the firmware supports Bluetooth version 4.1.
    12-24-2014 06:29 PM
  5. worwig's Avatar
    2013 Ford Mustang. I thought everything worked right. But today I got a text message, and I didn't get the notification on the car display.
    Not that I care, but my S4 used to link texts to the car display. The Note 4 doesn't.
    edit:
    Actually, it looks like it is working fine. Not sure why it didn't appear to work right that one time.
    12-24-2014 08:31 PM
  6. Cavboygt's Avatar
    Pioneer Honda pilot 2006 works great not like iPhone stop working because they upgrade the Bluetooth. My pioneer stereo is license by apple. Do the math weird do apple such a greedy company.
    12-24-2014 10:44 PM
  7. Goosty's Avatar
    2011 Toyota Camry hybrid works great.
    12-24-2014 11:37 PM
  8. LdotAdot13's Avatar
    2014 Ford Explorer Limited works perfect with my ford sync!
    12-25-2014 11:42 AM
  9. Slygrin's Avatar
    I didn't read all the post to see if mine was already listed. I'm connected to a 2012 Jeep Wrangler via uconnect. Every thing works great. Calls, SMS & streaming audio. It would not read SMS with my Note 2 so this was a good surprise.
    12-25-2014 12:08 PM
  10. emerrow's Avatar
    Toyota Prius 2014 works perfect but on my 2013 Ford Expedition King Ranch not so good
    Are you using the toyota's Entune interface? I'm unable to choose and play music through the Entune touch screen.
    12-25-2014 12:21 PM
  11. mgm83's Avatar
    2014 Dodge ram with uconnect system works great
    12-25-2014 12:39 PM
  12. pmccartney's Avatar
    2011 Infiniti G37S. Flawless Bluetooth connection for music player, Spotify, and the Google Maps voice guidance interrupts the music as required.
    Works great for phone calls as expected.
    12-26-2014 07:44 PM
  13. shastrich2005's Avatar
    My Note 3 worked amazing with my 2013 Camaro SS. You could control the Google Play through my Camaro's radio screen and everything displayed on the screen. The Note 4 not so much. Disappointing actually. Nothing displays on the screen and have to control it competely through the phone.
    12-26-2014 09:09 PM
  14. Invader3K's Avatar
    I have a Note 3 (4.4.4 on Verizon) and recently got a '14 Dodge Charger. I can send and receive phone calls. Voice command works to a limited degree. I can stream music, play, pause, and change tracks (with either the touch screen or the steering wheel controls)...however, metadata does not work at all, which is somewhat disappointing.
    12-27-2014 05:37 PM
  15. anon8126715's Avatar
    I've had trouble connecting before and I've found that removing all other BT devices from both devices you're trying to pair (clearing the cache and data when available) and re-pairing the devices helps.
    12-27-2014 06:38 PM
  16. AlfieBriggs's Avatar
    Works great with my 2014 Range Rover and Aston Martin DB9.
    Posted via my amazing Note 4 paired with my Moto360
    12-27-2014 07:34 PM
  17. srkirby's Avatar
    I have a 2014 Kia Rio Ex and my Note 4 pairs beautifully with it and our 2014 Kia Sorento. Zero problems with either one.
    12-27-2014 09:29 PM
  18. pappcam's Avatar
    2011 F150 with Sync and it all works including SMS but I don't use that feature as I don't need passengers reading my texts.
    12-27-2014 10:25 PM
  19. Jastow's Avatar
    2012 Lincoln MKX - connects automatically every time, voice dialing, Hangouts, Skype, plays music via bluetooth, and reads and displays text messgages. I havent been able to get it to respond to messages using Lincoln touch, but SVoice and Google Voice do the job. It may be that I'm just not doing something correctly. Overall, it works fine.
    12-28-2014 01:45 AM
  20. fulleraj's Avatar
    2014 Toyota Tacoma entune system - no issues whatsoever; have sync'd contacts with pics, phone works great with dialing and voice, and Bluetooth streaming audio works great.
    12-30-2014 09:56 AM
  21. kobe008's Avatar
    Got the Rogue and the Note 4 works great with it. It also has an option to change the connected device so if my wife's phone is the 'active' one on the BT I can do the change option and mine becomes primary. Works flawless.
    12-30-2014 10:46 AM
  22. Skydoll Eli's Avatar
    I have a Hyundai Genesis Coupe 2.0T 2013 and I purchased a Samsung Galaxy Note 4.. I was trying to connect bluetooth but I dont think it works..Im I doing something wrong??
    02-19-2015 02:47 AM
  23. Racinghart91's Avatar
    Seat MII for my business connects flawlesly and i can stream music on it via bluetooth.
    on my 99 civic it won´t par (it has no bluetooth kit) :-P
    02-19-2015 04:59 AM
  24. barrettdaniel's Avatar
    2013 Scion tC: flawless. The tc only allows voice calls and media playback, doesn't play videos or show contact pictures.
    02-19-2015 05:44 AM
  25. stewartt's Avatar
    Just curious to see if we could get a list of what cars everyone was able to pair/connect to their Note 4s. I know my Note 3 and my Kia don't exactly get along, which is funny considering both of them call the same place home. I'm hoping the Note 4 is more completely compatible, especially since there's a feature on my Kia that lets me see diagnostic and pair Point of Interest items between my phone and my car's Navigation system.
    Make/Model/Year and what if anything was or wasn't compatible would be nice.
    Thanks in advance!
    02-19-2015 02:32 PM
147 ... 3456
  1. Where can I download gmail and Google maps on Android?
    By Jeevith Chandrasekar in forum Android 5.0 Lollipop
    Last Post: 04-28-2015, 09:08 AM
  2. Replies: 6
    Last Post: 10-22-2014, 11:33 PM
  3. Note 4 UK release date being pushed back to 24th October?
    By thegame161 in forum Samsung Galaxy Note 4
    Last Post: 10-18-2014, 12:29 PM
  4. Watch "10 Hidden Features of the Galaxy Note 4
    By razortaz18 in forum Samsung Galaxy Note 4
    Last Post: 10-15-2014, 09:55 AM
  5. Replies: 1
    Last Post: 10-15-2014, 12:01 AM
