04-21-2015 09:56 AM
448 ... 1112131415 ...
tools
  1. emerrow's Avatar
    What do you disable and what is your screen time for this? Are you using any power saving modes during this time?
    My screen on time is about 2hrs so far. I disabled almost everything I could, honestly. All the software I didn't use (samsung/verizon software). I don't have any power saving modes on. I keep my screen brightness on auto.
    12-14-2014 05:36 PM
  2. emerrow's Avatar
    Does anyone know how to "disable" these bloat apps that come with the phones? I have Sprint.
    I went to "settings>Applications>Application manager" then I swiped to the right until you get the "all" list. Then just go down through and click the ones you don't use and either choose "turn off," "uninstall," or "force stop"
    godzillinois likes this.
    12-14-2014 05:40 PM
  3. makie's Avatar
    2 hours? Something must be wrong tho! You should easely get 4 hours...
    12-14-2014 06:23 PM
  4. naira1's Avatar
    7 hours screen time is insane!
    Is everyone who is getting this great battery life charging their phones to 100%? The counter doesn't reset until you do so, I was getting a day and a half readings before I realized that the counter wasn't resetting.
    Even if you charge it to 99% it may not reset. This is the only explanation I can think of, otherwise I would like to know every app and setting that people are using/not using so I can get this lol
    That's easy to confirm because even if the counter doesn't reset, you can see that on the battery graph. It will not be in a continuous downward trend like this.. So I guess this answer your question
    Sent from my SM-N910C using Tapatalk
    12-14-2014 08:41 PM
  5. emerrow's Avatar
    My battery was at about 48% with 2hrs of screen on time. I think thats somewhat decent? I've been trying to disable and uninstall as much unnecessary software as possible to boost my battery life
    12-14-2014 08:59 PM
  6. naira1's Avatar
    How's your signal strength? Do you use LTE all the time? And do you have good signal. Sometimes it's not just apps.
    12-14-2014 10:09 PM
  7. est0que's Avatar
    This just does not seem right. I've read about people heavily using their phone and getting like 10 hours. I've been lightly using it and already lost this much charge. It's really going to suck if I have to take this back and exchange it smh.
    edit:I changed the brightness from 50% to auto and I haven't used the phone that much.
    Here's an update with the screen time. My relative has the note 4 from the mobile and I checked his usage. It said his was on 11 hours on the battery and I think like 5 or 6 hours screen usage and he still had like 50 % left. BTW this charge I used Bluetooth ear buds and listened to like a hour or two of music and played Mario on a gba emulator for 30 minutes-1 hour.
    Edit: 5h 18m 8s on screen time 13 percent left 7 hours 15 minutes on battery.
    Is this normal? It just does not seem right to me. BTW I bought the phone 2 days ago and it has been fully charged only a couple of times.
    12-15-2014 03:03 AM
  8. dpham00's Avatar
    It seems about reasonable.
    Sent from my Verizon Samsung Galaxy Note 4
    12-15-2014 06:58 AM
  9. LaTuFu's Avatar
    A couple of things:
    The first few days battery life is always bad due to the phone indexing files, setting up the apps, you playing around with it, downloading updates, etc. It takes 3-5 days to "settle in" and start giving you typical performance.
    In my experience, I have found that leaving the screen on "auto" is not a good battery life technique in some situations. If you spend a lot of your time indoors due to work or school, there is no reason to set the screen on auto and have the CPU manage/monitor the screen bright. You can put the screen on manual and bump it down all the way to 5-15%, (just bright enough to read) enable dark themes on your most common readers, and get a pretty decent improvement on battery performance. Others might disagree, but I don't run auto on my screen unless I am going to be outside a lot.
    Playing video games is always going to impact battery. The CPU is running pretty solid, and the screen is always on (and you probably will want to bump it up higher than 5-15% for games if you go manual on brightness).
    12-15-2014 08:36 AM
  10. berryabusr88's Avatar
    Not to shabby. I took this a few days ago. Screen time was over 5 hrs. Best phone I've ever had period.
    Attached Thumbnails Note 4 - Post your battery life screens and info-screenshot_2014-12-12-19-00-20.jpg
    12-15-2014 08:52 AM
  11. ChemMan's Avatar
    Didn't use it that much but I left it in a ZERO cellular coverage area with only WIFI.
    Note 4 - Post your battery life screens and info-screenshot_2014-12-10-22-44-33-1-.jpg
    12-15-2014 08:54 AM
  12. godzillinois's Avatar
    http://i.imgur.com/470Op6X.png
    http://i.imgur.com/ILUVrZp.jpg
    http://i.imgur.com/ymFUta7.jpg
    http://i.imgur.com/sgyNfGU.jpg
    I'm not an expert, but I think it all depends on the screen time. Like, if I consistently used my phone after charging for 5 hours till dead, I should get 5 hours screen time and 5 hours battery life right? Or the 5 hours screen time can be spread out during the day?
    Following this logic, you're doing better than me. I get anywhere from 3-4.5 hours screen time. Your relative is getting insane numbers though, can you find out what they're doing? Does he use WiFi mostly? Does he live in the same area as you?
    12-15-2014 10:59 AM
  13. yeatzee's Avatar
    Mine is getting better and better. Averaging 7 hours lately. But I've uninstalled many apps that I hardly used. http://tapatalk.imageshack.com/v2/14...6cdfc74086.jpg
    Averaging 7 hours? Bull****, either you have the holy grail of Note 4's, are rooted with a bunch of stuff to help out, or are a straight zen master with your phone. Either way you definitely hold the title of longest lasting single battery. What's odd to me is the lack of app usage, if you had nearly 8 hours of screen on time what were you doing if your number #2 app was paypal and the next closest is voicecalls and tapatalk @ only 3% each. Really remarkable like I said.
    My day to day usage hovers around 5 hours to 5 and a half, and my all time record is 7 hours flat. I have zero complaints, but man these stats you posted are unbelievable.
    12-15-2014 11:55 AM
  14. naira1's Avatar
    Just amazing how people always look for something negative in everything. You my friend sound paranoid. I've even seen screen shot from other people with 8-9 hours sot in XDA. My phone is not rooted, but it's free from carriers bloat and I use my phone the way I deem fit. If you read some of my other post you will know I hardly play games and even when I do I get bored quickly.
    Phone is not rooted. But I trust you'll still look for something to complain about.
    12-15-2014 12:44 PM
  15. yeatzee's Avatar
    http://tapatalk.imageshack.com/v2/14...7da2b7d0b6.jpg
    Its amazing to me how somebody could be so sensitive and not read the numerous compliments, I called you a zen master for heavens sake lol. I saw that 9 hr SOT on xda, I think the key really is signal. His graph had almost entirely green from the beginning to the end, and looking at mine right now I show 3 bars of 4G but the battery stat is all yellow/tan colored for mobile signal. Also he was on 3G, no 4G. He also watched 2 full length movies, which the 805 is good at efficiently.
    You need to take a chill pill and not be so damn defensive, its a bad look.
    12-15-2014 02:08 PM
  16. naira1's Avatar
    I didn't get much love growing up that's why am sensitive . And i don't have any more pills to take maybe you can get me some. But I'll take the advise and chill.
    Meanwhile I don't even use my LTE signal that much. Mostly WCDMA/GSM is what I use and when am home or say work i just Wi-Fi. I have no use for LTE bcos it just suck my limited plan like a vampire.
    yeatzee likes this.
    12-15-2014 02:16 PM
  17. thetonyclifton's Avatar
    I have started breaking 7hrs SOT too a week into ownership. Not rooted, I did disable all the Samsung stuff I recognised and didn't want....but haven't touched anything I wasn't sure about - so it could be much cleaner.
    I use Greenify.
    I have location, Bluetooth, NFC switched off as I don't use them. My screen is set to about 10-15%. I have a couple of email accounts but sync manually. I mostly use the browser and the odd 20 minutes here and there on Facebook and twitter ditto the XDA app. I probably watch about 30-60 minutes of youtube.
    I use the s pen and Evernote to write meeting notes and a PDF reader to read and mark documents...that is probably worth and hour or so as an average.
    I probably only have about 20 minutes a day voice calls and a dozen or so texts.
    Off screen I probably use 60minutes of podcasts and music (often streamed).
    12-15-2014 03:19 PM
  18. makie's Avatar
    I've got a nice day today
    Attached Thumbnails Note 4 - Post your battery life screens and info-screenshot_2014-12-15-22-52-00.jpg
    12-15-2014 03:53 PM
  19. rdroyer's Avatar
    Not bad, put it into UPSM one night, Greenified everything the other. Battery percentage only dropped 2% Greenifying, didn't drop at all in UPSM.
    12-15-2014 04:26 PM
  20. Nakrohtap's Avatar
    This thread is turning into a sickness with everyone trying to squeeze every last minute of battery and screen on time out of their device.
    Just use your phone, people!
    I can see for the people that are getting less than stellar battery life to post in and try to get feedback from others. But, to start neutering all of your services on your phone just to get a little more screen on time is just silly.
    If you lose your power or charger and want your battery to last, put in ultra power saving mode. Otherwise, find the rogue apps causing the issues and just use your phone.
    This has been an editorial. Carry on. 😉
    Sent from my SM-N910V using Tapatalk
    iOSConvert2k14 likes this.
    12-15-2014 05:02 PM
  21. rdroyer's Avatar
    I can understand UPSM over night or if you're traveling by but there's definitely no reason for it on a daily basis, completely unnecessary.
    12-15-2014 05:31 PM
  22. godzillinois's Avatar
    I usually only use it over night since I don't want to leave my phone charging all night. But I keep my power charger at home and sometimes my phone gets low at work and so I'll have to turn on UPSM until I can connect to my car charger.
    12-15-2014 08:08 PM
  23. ChemMan's Avatar
    My ZeroLemon 10,000 MAh battery should be here in a couple days. It is in Kentucky on it's way.
    Note 4 - Post your battery life screens and info-10710410_748677611891849_7734621701089836987_o.jpg
    12-15-2014 10:51 PM
  24. thetonyclifton's Avatar
    I for one never switch off anything I want, I just dont want very many of Samsung's extra features and apps apart from the s pen. I spend the first few weeks switching off all the other stuff I don't use and making sure nothing is sucking my battery dry for no apparent reason. I do try and eek out extra power....so I can use my phone as much as possible. After a few weeks when I know the phone is running well and what it can do I tend to forget about it.
    12-16-2014 02:00 AM
  25. rsawitzky's Avatar
    Does this seem normal? If Im understanding this wrong, please correct me, but does this mean that I'm using my battery faster when my screen is off?
    Edit: I just realized how long it says since I've been off a charger, momentarily plugged in at meijer to print a picture, so maybe it means since then with the screen off I've used that much? Will check again tomorrow after normal use and update
    Attached Thumbnails Note 4 - Post your battery life screens and info-screenshot_2014-12-16-23-06-53.jpg
    12-16-2014 10:17 PM
  1. Sony Xperia Z3 Smart case and screen protector ott?
    By kevmiller82 in forum Sony Xperia Z3
    Last Post: 10-21-2014, 05:22 AM
  2. Why is my home screen dim with a full battery?
    By Shalonda Jackson in forum Displays
    Last Post: 10-19-2014, 05:56 PM
  3. Replies: 1
    Last Post: 10-18-2014, 04:13 PM
  4. Replies: 0
    Last Post: 10-18-2014, 02:54 PM
