04-21-2015 10:56 AM
448 ... 1415161718
tools
  1. sprint85's Avatar
    Does having sync on use my data?
    02-17-2015 09:44 PM
  2. leerandall's Avatar
    Normal usage for me is phone, email, texting, and web browsing, on a mix of wi-fi and cell data, with original factory-installed battery.
    Note 4 - Post your battery life screens and info-screenshot_2014-12-05-19-08-17.jpg
    Note 4 - Post your battery life screens and info-screenshot_2014-12-05-19-08-28.jpg
    Note 4 - Post your battery life screens and info-screenshot_2014-12-05-19-08-36.jpg
    02-17-2015 11:07 PM
  3. Brandwin's Avatar
    This is where I am at this morning
    Doesn't look good to me...
    Attached Thumbnails Note 4 - Post your battery life screens and info-screenshot_2015-02-18-08-49-44.jpg   Note 4 - Post your battery life screens and info-screenshot_2015-02-18-08-50-10.jpg   Note 4 - Post your battery life screens and info-screenshot_2015-02-18-08-50-18.jpg
    02-18-2015 09:55 AM
  4. Vladabeast's Avatar
    How in the hell do you do this
    Posted via my Samsung Galaxy Note 4
    02-18-2015 07:58 PM
  5. AlexMarie15's Avatar
    This is from my last full charge. This is typical for my heavy usage and it's bad. I'm not understanding how so many people are getting such great battery life. I want to be in on the secret, lol.
    Attached Thumbnails Note 4 - Post your battery life screens and info-1424318078967.jpg   Note 4 - Post your battery life screens and info-1424318091523.jpg
    02-18-2015 10:55 PM
  6. latinking91's Avatar
    Very happy with my battery life
    Posted via My Note 4
    Attached Thumbnails Note 4 - Post your battery life screens and info-screenshot_2015-02-19-15-19-08.jpg   Note 4 - Post your battery life screens and info-screenshot_2015-02-19-15-19-15.jpg   Note 4 - Post your battery life screens and info-screenshot_2015-02-19-15-19-22.jpg
    02-19-2015 08:28 PM
  7. bobxxz's Avatar
    That's actually pretty darn good battery life. Almost 4 hours with 30% left with heavy usage... I wouldn't be complaining with that. Most people that average 6+ SOT most likely aren't heavy users and have things turned off and/or have great signal.
    02-19-2015 09:21 PM
  8. donebrasko's Avatar
    WiFi has got to be killing my battery. It's not on but you see it's constantly running. Does anyone else have this problem? I may just wipe and start over
    Attached Thumbnails Note 4 - Post your battery life screens and info-screenshot_2015-02-19-21-22-36.jpg   Note 4 - Post your battery life screens and info-screenshot_2015-02-19-21-26-13.jpg   Note 4 - Post your battery life screens and info-screenshot_2015-02-19-21-26-18.jpg
    02-19-2015 09:27 PM
  9. clevin's Avatar
    it uses whatever data connection available, wifi, or data.
    02-20-2015 04:55 AM
  10. prodigeek's Avatar
    Here's mine... it stayed awake most of the time
    Attached Thumbnails Note 4 - Post your battery life screens and info-2015-02-20-18.01.06.jpg
    02-20-2015 08:22 AM
  11. donebrasko's Avatar
    What's your screen on time
    02-20-2015 11:53 AM
  12. kanderson326's Avatar
    I got a bigger battery 4800mAh and this is lighter usage for me.Note 4 - Post your battery life screens and info-uploadfromtaptalk1424485159322.jpgNote 4 - Post your battery life screens and info-uploadfromtaptalk1424485175428.jpg
    Sent from my SM-N910T using Tapatalk
    02-20-2015 09:19 PM
  13. prodigeek's Avatar
    Well based from that snippet above, around 6 hrs screen on time.
    02-21-2015 12:16 AM
  14. godzillinois's Avatar
    I got a bigger battery 4800mAh and this is lighter usage for me.Click image for larger version.
ID:	164191Click image for larger version.
    Where'd you get the bigger battery? I assume it makes the case bigger?
    03-23-2015 01:23 PM
  15. leerandall's Avatar
    I'm using the original stock battery.
    03-23-2015 05:16 PM
  16. godzillinois's Avatar
    Weird, I meant to quote Kanderson, but it quoted you too
    03-23-2015 08:34 PM
  17. Dr Noon's Avatar
    Oh man. Thats disappointing..
    Posted via Galaxy note4
    03-23-2015 11:25 PM
  18. Racinghart91's Avatar
    How can u get these stats ?
    how high is your brightness ?
    i am using greenify donation and try everything to increase my battery life but i could get 5 hours sot on the MAX normaly when i go to bed i have 40% left with 2 and half hour of SOT
    03-24-2015 05:46 AM
  19. mrtwohands's Avatar
    Moderate use[IMG]
    03-24-2015 02:31 PM
  20. kanderson326's Avatar
    eBay... This one's from acesoft, says specific for t-mobile... There are some for other carriers as well. Seems to last a little longer, using off and on for over a month now, no issues... and yes it's made in China.
    http://m.ebay.com/sch/i.html?_nkw=ac...acesoft+note+4
    03-26-2015 05:41 AM
  21. kanderson326's Avatar
    It's the same size as factory, but I think this has no NFC. There are some other brands that may keep NFC. It has lasted 2 days if you play nice, but I have gotten close to that with factory battery as well, so who knows, but seems to last a little longer.
    03-26-2015 06:04 AM
  22. kpdx's Avatar
    24 hours in on lolipop.
    Unplugged from charger 5:1 5pm
    Posted this at 3:05am
    25% remaining after 9ish hours on battery.
    6 hours 15 minutes screen time.
    Attached Thumbnails Note 4 - Post your battery life screens and info-screenshot_2015-03-26-03-03-20.jpg   Note 4 - Post your battery life screens and info-screenshot_2015-03-26-03-03-33.jpg
    03-26-2015 06:08 AM
  23. Since9600's Avatar
    This what I get when I mostly use my Gear S for checking/typing almost all messages and the occasional call.. Not bad at all.... I have battery use down to a science lol..
    Note 4 - Post your battery life screens and info-screenshot_2015-03-26-05-52-14.jpg
    03-26-2015 09:41 AM
  24. kirksucks's Avatar
    Should I be concerned?
    Attached Thumbnails Note 4 - Post your battery life screens and info-1427382615090.jpg
    03-26-2015 11:10 AM
  25. godzillinois's Avatar
    Wait, so there's a bigger capacity battery out there that's the same size as the factory? I'd sacrifice NFC if that's true
    03-27-2015 01:58 PM
448 ... 1415161718
  1. Sony Xperia Z3 Smart case and screen protector ott?
    By kevmiller82 in forum Sony Xperia Z3
    Last Post: 10-21-2014, 06:22 AM
  2. Why is my home screen dim with a full battery?
    By Shalonda Jackson in forum Displays
    Last Post: 10-19-2014, 06:56 PM
  3. Replies: 1
    Last Post: 10-18-2014, 05:13 PM
  4. Replies: 0
    Last Post: 10-18-2014, 03:54 PM
