04-21-2015 09:56 AM
448 ... 15161718
tools
  1. godzillinois's Avatar
    How can u get these stats ?
    how high is your brightness ?
    i am using greenify donation and try everything to increase my battery life but i could get 5 hours sot on the MAX normaly when i go to bed i have 40% left with 2 and half hour of SOT
    I get 3.5 hours SOT, I'd be lucky if I got 4.
    03-27-2015 12:59 PM
  2. godzillinois's Avatar
    24 hours in on lolipop.
    Unplugged from charger 5:1 5pm
    Posted this at 3:05am
    25% remaining after 9ish hours on battery.
    6 hours 15 minutes screen time.
    Is this better or worse than you were getting before Lollipop? I feel like mines slightly worse after upgrading
    03-27-2015 12:59 PM
  3. godzillinois's Avatar
    I just noticed something, if you look at the "Mobile Network Signal" bar graph in the attached screen shot, there's an awful lot of orange there. I remember reading somewhere that red means no signal, anyone know what orange means? Could this be affecting my battery life?
    Attached Thumbnails Note 4 - Post your battery life screens and info-1427493525095.jpg
    03-27-2015 05:00 PM
  4. bbmjack's Avatar
    Should I be concerned?
    It's alright
    Screen awake means your phone screen opened
    Mobile network when it's green it's full
    KRASIVA
    03-27-2015 05:16 PM
  5. kanderson326's Avatar
    Wait, so there's a bigger capacity battery out there that's the same size as the factory? I'd sacrifice NFC if that's true
    It's pretty common for third parties to manufacture aftermarket batteries for these devices. Here's a link for the "acesoft" brand I got on eBay but there are others around also and depending on your model number...
    http://pt.tapatalk.com/redirect.php?...oft%2Bnote%2B4
    Sent from my SM-N910T using Tapatalk
    03-28-2015 04:35 PM
  6. godzillinois's Avatar
    It's pretty common for third parties to manufacture aftermarket batteries for these devices. Here's a link for the "acesoft" brand I got on eBay...
    I'm only seeing batteries for the Galaxy Note Edge, would those work in the Note 4?
    03-28-2015 06:19 PM
  7. Andy847's Avatar
    I'm getting a little more drain on the battery, nothing I'm worried about. It's not bad. I'm not a power user. I have been using more since the update too. I'm still able to get through the day with it no problem. Today didn't use too much.
    03-28-2015 06:30 PM
  8. kanderson326's Avatar
    If you scroll down there's the ones for note 4, and it should work if you just search your model number and "battery" or "note 4 battery"
    03-28-2015 07:48 PM
  9. varunaX's Avatar
    I was streaming ultra music festival all day with twitch
    Attached Thumbnails Note 4 - Post your battery life screens and info-1427591721620.jpg   Note 4 - Post your battery life screens and info-1427591740240.jpg
    03-28-2015 08:16 PM
  10. godzillinois's Avatar
    Ok that's out of control, 6 SOT with 49% battery left? That's already over 2 hours more screen time than me and you're barely halfway through your battery!
    There's gotta be something we're missing here, I see people getting 3-5 SOT, but then there's people doubling or almost tripling that! HOW?!
    We gotta solve this -how many people getting over 5 hours SOT have Sprint? How many are using a micro sd card? Anyone super knowledgeable on reading all the bar graphs and stats in the power section?
    imex99 likes this.
    03-29-2015 12:03 AM
  11. AmBieMZ's Avatar
    How to get 6 hrs of SOT? I barely manage to get 4 hrs
    - N910H
    Posted via Note 4
    03-29-2015 07:14 AM
  12. imex99's Avatar
    Agreed, please, more information as requested.... Carrier, etc...
    bbmjack likes this.
    03-29-2015 07:48 AM
  13. mountainbikermark's Avatar
    AT&T, lollipop 5.0.1
    Inserted screen on time below screen % using picsay pro . Auto bright, Power save on, Wi-Fi and data network on, Bluetooth on and connected to Gear S.
    I usually get better than this but I've been in craptacular reception most of the day today.
    03-29-2015 08:42 PM
  14. Racinghart91's Avatar
    i got great stats this weekend !
    I juiced my phone friday night, and i did not have to charge it for the whole weekend !
    After the BOC3 update i removed greenify and some system apps, i never use power saving and my brightness is around 40%.
    no more concerns for flashing a custom rom, this build is awesome !
    03-30-2015 06:41 AM
  15. clevin's Avatar
    My bet is he or she has a 6500 or 10000 mah extended battery.
    imex99 likes this.
    03-30-2015 07:27 AM
  16. Racinghart91's Avatar
    so is it really true that the micro sd card drains battery ?
    i have a 8gb cheap sd card inside my phone but there is nothing on it..
    03-30-2015 07:38 AM
  17. Since9600's Avatar
    SD does not drain battery, unless you are constantly using it, same as if you was constantly using the internal memory. I get insane battery time and I have over 70 gigs of files on my SD..
    03-30-2015 10:29 AM
  18. varunaX's Avatar
    Oh oops sorry guys, of course I have the 6500mah battery, I don't know why I didn't mention that.
    I definitely recommend it. I get 10 of sot and it's not that much thicker.
    03-30-2015 04:27 PM
  19. godzillinois's Avatar
    Well that explains it
    03-31-2015 12:37 AM
  20. godzillinois's Avatar
    http://tapatalk.imageshack.com/v2/15...7438e98638.jpg
    http://tapatalk.imageshack.com/v2/15...fd7e55ac5d.jpg
    If I were to use power saving mode I'd get around that too, probably more actually. Do you have power saving mode on all the time? I don't see your screen in gray scale mode
    I think most everyone (including myself) is assuming what you post is without any power saving modes or extended batteries unless specified.
    03-31-2015 12:39 AM
  21. Princepia's Avatar
    I'm a moderate to heavy user. Done some tweaking and I'm super satisfied with my battery life. Especially coming from an S3. Love it.
    Attached Thumbnails Note 4 - Post your battery life screens and info-screenshot_2015-03-31-01-54-34.jpg   Note 4 - Post your battery life screens and info-screenshot_2015-03-31-01-54-59.jpg
    03-31-2015 01:58 AM
  22. kpdx's Avatar
    The battery seems like the same to me. I would say I am a heavy user. I am constantly browsing forums, web searches, streaming music, and viewing images. It is my main source of entertainment.
    I always have power saving enabled (not the ultra saving). My screen is on auto most of the time. I disabled the back lights (recent apps, back button) I did this because the lights hurt my eyes in the dark. I know where the buttons are. No need for my phone to hi beam me.
    03-31-2015 05:07 AM
  23. Divya Kapoor's Avatar
    oki good one
    03-31-2015 05:09 AM
  24. mountainbikermark's Avatar
    The card doesn't use battery. Using the card reader inside the phone to access data on the card is what uses the battery.
    03-31-2015 03:10 PM
  25. mountainbikermark's Avatar
    Power save as I have it set doesn't make any difference until the battery drops below 15% then auto kicks on Ultra Power Saving Mode.
    Power Save as I have it set
    Note 4 - Post your battery life screens and info-uploadfromtaptalk1427833062208.jpg
    Ultra, which I have off.
    Note 4 - Post your battery life screens and info-uploadfromtaptalk1427833078214.jpg
    03-31-2015 03:18 PM
448 ... 15161718
  1. Sony Xperia Z3 Smart case and screen protector ott?
    By kevmiller82 in forum Sony Xperia Z3
    Last Post: 10-21-2014, 05:22 AM
  2. Why is my home screen dim with a full battery?
    By Shalonda Jackson in forum Displays
    Last Post: 10-19-2014, 05:56 PM
  3. Replies: 1
    Last Post: 10-18-2014, 04:13 PM
  4. Replies: 0
    Last Post: 10-18-2014, 02:54 PM
