04-21-2015 09:56 AM
448 ... 23456 ...
tools
  1. mchi5's Avatar
    Any word when that may be? i checked the site and saw nothing but a screen protector
    also to bump……
    Hey maybe a stupid question but I'm a noob is it better when new to let the battery completely drain before charging?? what charging process would you use to optimize battery life?
    I messaged both zerolemon and Anker and both will release their extended batteries around Christmas time
    For your second question I've heard just charge whenever you need to. But it's best not to let the battery drop all the way to 0 all the time. But what I've read
    Sent from my new Note 4 via Tapatalk
    mcalise133 likes this.
    10-20-2014 08:45 PM
  2. mcalise133's Avatar
    Now for the next question and please excuse me if this is a inappropriate space for this but…. which brand is perffered? anker or zero lemon ? if preferred ill start a separate thread.
    10-20-2014 08:48 PM
  3. reesh11's Avatar
    I can't really complain about the battery life. Last night I watched Grease on my phone via Netflix and only lost about 8%. Now that is saying something in my opinion. I gotta say I love the extra battery kit tho. Thanks dpham!
    10-20-2014 08:49 PM
  4. butterfly210's Avatar
    Battery charge not great..
    Attached Thumbnails Note 4 - Post your battery life screens and info-1413856719884.jpg
    10-20-2014 08:59 PM
  5. irishc6's Avatar
    When I got the phone 2 days ago drain was bad. I had same issue with S5 until I changed runtime system to ART in dev. options.
    Try that maybe it will help.
    Sorry, I'm new to the Android platform. When you use Art runtime do you still get app and system updates?
    10-20-2014 09:16 PM
  6. Almeuit's Avatar
    You can't really judge the battery on 16 minutes of usage... That's way too little .
    10-20-2014 09:18 PM
  7. JGill2401's Avatar
    Bluetooth normally off, I turn it on manually when I get in the car and also when I am at the gym.
    Wi-Fi is ALWAYS on, especially since my T-Mobile signal is weak to non-existent in my condo.
    NFC is ALWAYS off.
    Rocking the Note 4 naked while I wait for my Samsung (Protective, not S-View) case to arrive on Thursday.
    Is your location on high accuracy, power saver or GPS? Sorry for asking all these questions, but I'm really trying to get better battery life.
    10-20-2014 10:01 PM
  8. Ncontrl's Avatar
    Note 4 - Post your battery life screens and info-screenshot_2014-10-20-13-02-02.jpgNote 4 - Post your battery life screens and info-screenshot_2014-10-20-13-02-16.jpg
    After a full charge maybe every 3 hours or so I might lose 1% of not using the Note 4 on AT&T. I believe I get pretty good battery life.
    10-20-2014 10:01 PM
  9. Almeuit's Avatar
    I keep mine on high accuracy.
    10-20-2014 10:32 PM
  10. da3lynx's Avatar
    Here's mine
    Pretty decent with music streaming on lte, some gaming, and messaging and phone calls throughout the day
    10-20-2014 10:48 PM
  11. sodaboy581's Avatar
    High Accuracy.
    10-21-2014 08:19 AM
  12. beavo451's Avatar
    After more use, it seems like the battery will be plenty to get me through a typical day. I also turned on a bunch of features to test standby time while I slept. WiFi on, Bluetooth on, NFC on, Google Now on, Google Now voice detection set to always listen, push exchange email, etc. Looses 1% for every hour of standby.
    10-21-2014 09:31 AM
  13. mchi5's Avatar
    Well they're both different. On the note 3 at least the Anker was 6400 mah, so basically double the stock battery. It was lighter than zerolemon but still have about 1.5 days until a charge.
    Zerolemon on the note 3 was 10,000 mah battery so a major beast. It can last 2.5-3 days until charge. However it was a lot heavier and bulkier than the Anker. So it all depends on what you wanted more. Crazy more battery But didn't mind the heft or double the battery with the Anker but still almost like stock
    I know because I had both for the Note 3. . I assume the note 4 versions will be fairly similar
    10-21-2014 10:41 AM
  14. Almeuit's Avatar
    Okay here is mine. I will list what I did below.
    WiFi and VoLTE calls (about an hour and a half worth)
    Browsing the forums / taking screenshots on LTE and Wifi.
    Pictures and many text / mms messages
    Streaming a little video and music (with Bluetooth headset).
    I have GPS (location) on all the time on high accuracy and have the weather widget refresh hourly. The ONLY thing I've shut off on the phone is the "Air Gestures" or whatever they're called (for swiping your hand to change pages and stuff).
    The very last bit of the battery (the plummet) was from my hotspot running for an hour and a half or so for my coworker. He was uploading photos to iCloud using my LTE connection.
    Edit - also yes I've received the battery update thanks to T-Mobile.
    Attached Thumbnails Note 4 - Post your battery life screens and info-1413908131036.jpg   Note 4 - Post your battery life screens and info-1413908139161.jpg   Note 4 - Post your battery life screens and info-1413908147012.jpg
    10-21-2014 11:18 AM
  15. Almeuit's Avatar
    And I'm back to 100 % while that dead battery charges... Yay for spare batteries .
    bassplayrguy likes this.
    10-21-2014 11:23 AM
  16. JGill2401's Avatar
    This is my stats so far. I have bluetooth, wi-fi, location, push notifications from Gmail, wsj, espn, team stream on, NFC off, and auto brightness. Clearly I'm considered more of a heavy user. Is this good battery so far? This is my FIRST Android phone ever and I'm still trying to learn the OS and device.
    Attached Thumbnails Note 4 - Post your battery life screens and info-1413908831356.jpg   Note 4 - Post your battery life screens and info-1413908854976.jpg   Note 4 - Post your battery life screens and info-1413908868527.jpg
    10-21-2014 11:30 AM
  17. bassplayrguy's Avatar
    I think this is good
    Attached Thumbnails Note 4 - Post your battery life screens and info-screenshot_2014-10-21-18-15-25.jpg   Note 4 - Post your battery life screens and info-screenshot_2014-10-21-18-15-18.jpg
    10-21-2014 08:12 PM
  18. Daniel P1's Avatar
    What was your brightness level at?
    10-21-2014 08:46 PM
  19. Keltian's Avatar
    I contacted Zerolemon and they told me "Hello, we will release our note 4 and note edge batteries by approximately the end of October to mid November. As of yet we do not have a specification of the battery."
    10-21-2014 10:02 PM
  20. mchi5's Avatar
    Yeah I heard someone else got your reply. Who knows. I wouldn't mind it coming in November. But they told me around the holidays 😒
    10-21-2014 10:13 PM
  21. jokesonme's Avatar
    I think they use around the holidays so they don't have to specify which one. There's basically at least one a month lol
    10-22-2014 12:13 AM
  22. JGill2401's Avatar
    My brightness was on auto. I will post my updated status soon.
    10-22-2014 09:15 AM
  23. JGill2401's Avatar
    Here are my updated stats at the end of the day. I had my bluetooth LG tone headphones connected all day until that died. I had power saving mode on and my auto-brightness on. I would considered my usage yesterday heavy as I had music or podcasts playing, all push notifications from different sources, some facebooking, downloading and etc. What do you guys think about these stats?
    Attached Thumbnails Note 4 - Post your battery life screens and info-screenshot_2014-10-21-20-36-55.jpg   Note 4 - Post your battery life screens and info-screenshot_2014-10-21-20-37-01.jpg   Note 4 - Post your battery life screens and info-screenshot_2014-10-21-20-37-05.jpg   Note 4 - Post your battery life screens and info-screenshot_2014-10-21-20-37-10.jpg
    10-22-2014 09:26 AM
  24. clevin's Avatar
    seems reasonably for your usage.
    10-22-2014 09:46 AM
  25. mchi5's Avatar
    Has anyone used the ultra power saving mode? Does it really work as advertised?
    Haven't used it yet but good to know its there in case my Note 4 is about to die
    10-22-2014 10:27 AM
448 ... 23456 ...
  1. Sony Xperia Z3 Smart case and screen protector ott?
    By kevmiller82 in forum Sony Xperia Z3
    Last Post: 10-21-2014, 05:22 AM
  2. Why is my home screen dim with a full battery?
    By Shalonda Jackson in forum Displays
    Last Post: 10-19-2014, 05:56 PM
  3. Replies: 1
    Last Post: 10-18-2014, 04:13 PM
  4. Replies: 0
    Last Post: 10-18-2014, 02:54 PM
